I have like this automation that should be triggered by certan condition. like in my case a value of the sensor if it is below 0.5. the sensor value is atm 0, so a notification will show up. But if I change it to above 0.5 unforunately the same notification will show up.
Hope you can help me in may case.
thank you for the fast anwer. So in my situation the sensor value of the battery is about 0.65 (voltage divider)
In case of dropping too low it should trigger the automation. I’m only testing it in Home Assistant by execute the automation manually.
At first I had like this in mind but it didn’t work as well
