Automation with pump water and two tanks
Dear,
I’m doing an automation for triggering tank1000’s pump in situations:
  • When the Tank3000 runs out of water and the
    • “sensor up” on and
    • “sensor down” on
      and
  • Tank1000 is with
    • “sensor down” off
action
  • Turn on the “tank1000 relay” to refill the tank.
case
  • tank1000 is with the “sensor down” on
    action
    turns off the “tank1000 relay”.
follows code:
alias: "Tank water pump - on"
   - platform: mqtt
     topic: 'stat / tank3000 / POWER2'
     payload: 'ON'
condition:
   condition: and
   conditions:
     - condition: state
       entity_id: switch.tank3000_sensor_up
       state: 'ON'
     - condition: state
       entity_id: switch.tank1000_sensor_down
       state: 'OFF'
   service: switch.turn_on
   entity_id: switch.tank1000_relay
configuration of tanks:
tank1000
  • Toggle1 = relay
  • Toggle2 = sensor up
  • Toggle3 = sensor down
Sensors:
toggle2 e toggle3
off = tank with water
on = tank without water
tank3000
  • Toggle1 = sensor up
  • Toggle2 = sensor down
Sensors:
toggle1 e toggle2
What exactly is your question? I’m not sure what it is that you’re after…
My automation is not working.
I wonder what’s wrong!
Thank you
I don’t think you can have spaces in your topic.
Thank you,
was check in the code and does not have this space, it was a small typo.Thank you,
‘stat/tank3000/POWER2’
check inthe state table that your state and topic payload are actually “ON” and not “on” etc.
“ctrl +c” and “ctrl +v”
  - platform: mqtt
    topic: 'stat/tank3000/POWER2'
    payload: 'ON'
condition:
  condition: and
  conditions:
    - condition: state
      state: 'ON'
    - condition: state
      state: 'OFF'
Checked !! OK !!
Are your sensors switches or sensors? and are the names correct as stated in the switches/sensors part of the state table?
Yes they are.
The sensors are reed switch.
All the names are declared correctly and I simulate the states.
How do you do this?
Actuating the sensors!
- condition: state
  state: 'ON'
- condition: state
  state: 'OFF'
I suspect the reason it isn’t triggering is that the states need to be ‘on’ and ‘off’.
If you look in the states table, you will find the only things that are uppercase are any input_selects that you have defined as uppercase. At least that’s the case in mine :wink:
Keithh66,
I will describe my simulation scenario:
tank3000
###### Tank3000
  - platform: mqtt
    name: "tank3000 sensor up"
    state_topic: "stat/tank3000/POWER1"
    command_topic: "cmnd/tank3000/POWER1"
    qos: 1
    payload_on: "ON"
    payload_off: "OFF"
    retain: true
  - platform: mqtt
    name: "tank3000 sensor down'"
    state_topic: "stat/tank3000/POWER2"
    command_topic: "cmnd/tank3000/POWER2"
    qos: 1
    payload_on: "ON"
    payload_off: "OFF"
    retain: true
tank1000
###### Tank1000
  - platform: mqtt
    state_topic: "stat/tank1000/POWER1"
    command_topic: "cmnd/tank1000/POWER1"
    qos: 1
    payload_on: "ON"
    payload_off: "OFF"
    retain: true
  - platform: mqtt
    name: "tank1000 sensor up"
    state_topic: "stat/tank1000/POWER2"
    command_topic: "cmnd/tank1000/POWER2"
    qos: 1
    payload_on: "ON"
    payload_off: "OFF"
    retain: true
  - platform: mqtt
    name: "tank1000 sensor down"
    state_topic: "stat/tank1000/POWER3"
    command_topic: "cmnd/tank1000/POWER3"
    qos: 1
    payload_on: "ON"
    payload_off: "OFF"
    retain: true
In this situation I would like automation to trigger relay tank1000:
In this situation I would like the automation to work!
As you can see, the relay was not activated.
What I would like automation to do would be:
but unfortunately it does not happen !:
here is the automation code:
  - platform: mqtt
    payload: 'ON'
condition:
  condition: and
  conditions:
    - condition: state
      state: 'ON'
    - condition: state
      state: 'OFF'
I found the error:
had a ’
in:
for
     name: "tank3000 sensor down"
Thank you for your help !!
Glad you got it working :smile: , next time post all of the config not just what you think is not working :stuck_out_tongue:
