Automation with Repeat Function
Recently I changed my water heater HA operation from the Rheem EcoNet cloud based control to the ESPHome EcoNet control. That was highly successful and worked flawlessly except in one case. There is an automation in my HA which at a defined time changes the mode and temperature settings of the water heater. This had always worked in the previous setup (not so much when Rheem EcoNet was down) but now it frequently failed to adjust the temperature. Strange as it seems, it never failed when the automation was triggered manually.
I modified the automation with time delays between the mode change and the temperature change in case the serial messages were stepping on each other. That had no effect on the problem. Next I used the ‘repeat-until’ function for the temperature change action and this has ,so far, not failed. For some reason when this was first implemented, I never got a trace. That has not reoccured since recreating the automation from scratch (???). The concern I am having now is weirdness in the trace when the automation exits. There is an ‘unknown’ in the trace on exit and also the automation exits on an ‘abort.’ Perhaps this is normal and it is not affecting the operation. An abort would seem to indicate that there is not a clean exit.
Automation code:
alias: Bedtime_HW_Test
description: ""
  - platform: time
    at: "20:30:00"
condition: []
    data: {}
      entity_id: input_boolean.override
  - service: switch.turn_on
    data: {}
      entity_id: switch.hw_recirc
  - service: climate.set_preset_mode
      preset_mode: Performance
      entity_id: climate.econet_etwh_water_heater
  - repeat:
      sequence:
        - service: climate.set_temperature
            temperature: 135
        - delay:
            hours: 0
            minutes: 0
            seconds: 10
            milliseconds: 0
      until:
        - condition: numeric_state
          attribute: temperature
          above: 130
  - condition: state
    state: "135"
    for:
      hours: 0
      minutes: 0
      seconds: 5
mode: single
Trace result:
What is the purpose of the final Condition action? If there are no further actions, there is no need for a condition.
That condition was just something left over from the many iterations of the automation and had no purpose. That being said, it turns out that by creating an error it actually made the automation work. By eliminating that condition the repeat function went into a infinite loop. I tried all of the variations of the repeat function and they all put the automation in a loop. The looping is why there was never a trace available. Obviously there was something wrong in the repeat function condition test but I was unable to discover the problem. In the end I decided to rebuild the automation in its original configuration. This has been working now for nearly a week. Why it originally failed remains a mystery except that there have been several ESPHome firmware updates in the meantime. A mystery I am willing to dismiss.
