I have some cameras that start recording through and automation whenever the alarm is triggered. In the past all cameras started recording in parallel with a few seconds delay but with latest version 2023.7.2 (not sure when the behavior changed…) the second recording only start when the first finishes and so on which turn the automation useless. Here is the crop of the automation
- choose:
- conditions:
- condition: template
value_template: >
{{ (trigger.event.data['Entity']|string) == 'Alarm'
sequence:
- service: camera.record
entity_id: camera.camera_portao_exterior
duration: 180
filename: /config/www/record/dskv8113.mp4
entity_id: camera.camera_porta_interior
duration: 180
filename: /config/www/record/dskv6113.mp4
entity_id: camera.hikvision_camera_exterior_jardim_mainstream
duration: 180
filename: /config/www/record/ds2cd2385fwdi.mp4
entity_id: camera.hikvision_camera_garagem_mainstream
duration: 180
filename: /config/www/record/ds2cd2f42fwdiws.mp4
entity_id: camera.hikvision_camera_exterior_portoes_mainstream
duration: 180
filename: /config/www/record/ds2cd2185fwdis.mp4
Is this a bug introduced? Or it is designed to work like that and before it was not supposed to work in parallel.
Any comment is more than welcome.
