Automation with templates - notification / switch
I’m not sure how to get around of this:
I want to display who is on the phone, so I created a couple of entities (the phones) as switches. If the phone is picked, the switch should turn ‘on’, if the person’s is hanging up, the switch should turn ‘off’.
The Trigger would be a webhook, which is initiated by our phone service provider (placetel). So I wanted to setup automations to trigger the switches. We got multiple phones (peer), but only one landline (to).
This is what the payloads look like:
Phones are ringing:
{"call_id":"asdh32847asdhq8zdhaidhj3ueaskdhajdh298hdadhaj","direction":"in","event":"IncomingCall","from":"000111111","to":"222233333"}
Somebody (the peer) is picking up:
The Peer is Hanging up:
{"call_id":"asdh32847asdhq8zdhaidhj3ueaskdhajdh298hdadhaj","direction":"in","duration":601,"event":"HungUp","from":"000111111","to":"222233333","type":"accepted"}
I somehow had the idea to use a temporary entity:
service: persistent_notification.create
  message: '{{ trigger.data.peer }}'
  notification_id: '{{ trigger.data.call_id }}'
how do I implement this? This fails because of the data_template. How get I to create messages with templating?
alias: placetel_notify_api
description: ''
  - platform: webhook
    webhook_id: placetel_notify_api
condition: []
  service_template: >
    {% if (trigger.data.event == 'CallAccepted')) -%}
    {%- else -%}
    switch.turn_off
    {%- endif %}
  data_template:
      message:  "{{ trigger.data.peer }}"
      notification_id: "{{ trigger.data.call_id }}"
      {%- else -%}
      entity: switch."{{ trigger.data.peer }}"
      {% endif %}
mode: single
Thanks!
Try the following. ( The use of the “x_template” format has mostly been deprecated, and you were missing a “>”)
description: ''
  - platform: webhook
condition: []
  service: >
    {%- else -%}
    switch.turn_off
    {%- endif %}
  data: >
      {%- else -%}
      {% endif %}
mode: single
you can’t add more than one key:value pair inside of a template like that:
  service: >
    {%- else -%}
    switch.turn_off
    {%- endif %}
  data: >
      message:  "{{ trigger.data.peer }}"   ### this won't work
      notification_id: "{{ trigger.data.call_id }}"  ### with this
      {%- else -%}
      {% endif %}
you should use a “choose:” option to set the persistent notification with the correct data if the call is accepted or else choose the switch actions:
  choose:
    - conditions:
        condition: " {{ (trigger.data.event == 'CallAccepted')) -}}"
      sequence:
  default:
    service: switch.turn_off
      entity_id: switch."{{ trigger.data.peer }}"
it’s untested so I’m not 100% sure of the syntax.
The only way you can template fields is if you use a dictionary. Also, data_template is deprecated, just use data.
  data: >
      {{ {'message': trigger.data.peer, 'notification_id': trigger.data.call_id} }}
    {% else %}
      {{ {'entity': 'switch.' ~ trigger.data.peer } }}
    {% endif %}
thanks so much!
@finity gave me the final input. I didn’t think about conditions in the actions. Works frickin great now!
So for whoever also has placetel as an carrier here’s the automation to change your status.
The only thing you have to setup is the switches. The placetel userids are [someint]@fpbx.de.
My switches are uid[someint].
alias: placetel Notify API
description: 'Incoming Post request from placetel: https://web.placetel.de/integrations/notify_api. You have to subscribe to that API'
  - platform: webhook
condition: []
  - choose:
      - conditions:
          - condition: template
            value_template: '{{ trigger.data.event == "CallAccepted" }}'
        sequence:
          - service: persistent_notification.create
              message: uid{{ trigger.data.peer.split("@")[0] }}
          - service: switch.turn_on
              entity_id: switch.uid{{ trigger.data.peer.split("@")[0] }}
  - choose:
      - conditions:
            value_template: '{{ trigger.data.event == "HungUp" }}'
            value_template: >-
              {{ state_attr('persistent_notification.'+trigger.data.call_id,'message') != '' }}
        sequence:
          - service: switch.turn_off
              entity_id: >-
                switch.{{state_attr('persistent_notification.'+trigger.data.call_id,'message')
          - service: persistent_notification.dismiss
    default: null
mode: single
grafik
Still got some styling to do. But ot works decent, and people are happy :slight_smile:
you don’t need to use two choose statements.
just put both under the same one. And you don’t really need a default either:
    - choose:
      - conditions:
        sequence:
      - conditions:
            value_template: >-
        sequence:
              entity_id: >-
