ibennani
(Ilias Bennani)
1
Here’s a probably simple one.
The automation below will never run.
I have checked the Jinja in the template console and it does return true or false when it shall. Still the automation never executes.
This automation shall execute
at 16:00:00 if sunset does occur before 16:00:00
or
at sunset if sunset does occur after 16:00:00
- alias: "Some alias text"
value_template: >-
{{ (now().strftime('%T') <= (states.sensor.sunset_time.state ~ ':00' )
and now().strftime('%T') == "16:00:00" )
or
(now().strftime('%T') == (states.sensor.sunset_time.state ~ ':00' )
and now().strftime('%T') >= "16:00:00") }}
some code here
According to the documentation, I shall be able to use a template trigger as in my code above.
You can’t use now() in a trigger template because now() is only evaluated ‘at this moment’, use the time sensor.
ibennani
(Ilias Bennani)
3
Just for the cause of documentation and for future readers, here’s how I solved this automation:
- platform: time
at: '16:00:00'
value_template: '{{ states.sensor.sunset_time.state ~ ':00' }}'
condition:
- condition: template
value_template: >-
or
( now().strftime('%T') == (states.sensor.sunset_time.state ~ ':00' )
some code here
