I’m migration my home automation from another system to HA, and am a bit lost in the yaml syntax.
I have a input select entity with two options: “Disconnected from grid” / “Connected to grid”, configured in configurations.yaml
input_select:
inverter_mode:
options:
- "Disconnected from grid"
- "Connected to grid"
initial: "Connected to grid"
icon: mdi:target
For each of these options I created a rule file to send the appropriate command (to disconnect / connect the inverter from the grid) via MQTT to the inverter.
Everything is working perfectly fine.
My question: how can I combine the two rule files into a single rule file? My solution works, but feels so messy.
inverter_set_mode_connected.yaml
alias: "Set Inverter Mode Connected"
platform: state
entity_id: input_select.inverter_mode
to: "Connected to grid"
service: mqtt.publish
topic: victron/W/7c3866560fa4/vebus/261/Mode
payload: '{"value": 3}'
inverter_set_mode_disconnected.yaml
alias: "Set Inverter Mode Disconnected"
platform: state
to: "Disconnected from grid"
payload: '{"value": 2}'
NB - the forum is warning me about unformatted code. How do I fix it?
