- platform: time
at: "18:45:00"
- platform: sun
event: sunset
offset: 0
condition:
- condition: time
before: "00:00:00"
after: "18:45:00"
- condition: sun
after: sunset
I assume that both of these conditions need to be true for the automation to activate the action. Correct? Assuming this is correct, how would I change this the automation if I wanted to activate the action when the first condition becomes true?
Thanks, but I do not believe that you are correct. In the current case, when both conditions need to be true, the action is activated at the later time. Thus, if sunset happens after xx:xx, the action activates at sunset, otherwise it activates at the time xx:xx.
What I am asking is this: make the action activate at the earlier of xx:xx or sunset.
It will do that without the need for any conditions.
I think what you want is for the automation to only execute once per day, not twice. For example, if sunset is at 18:50, the automation will trigger twice, the first time at 18:45 (Time Trigger) and the second time at 18:50 (Sunset Trigger).
You can restrict the automation to execute just once for any given day like this:
If it doesn’t matter that it’s executed twice then your automation already does what you requested:
If today’s sunset time is at 18:35 then the Sun Trigger will occur before the Time Trigger (which will execute the automation a second time at 18:45).
If today’s sunset time is 18:50 then the Time Trigger will occur (at 18:45) before the Sun Trigger (which will execute the automation a second time at 18:50).
It executes at the earliest time first, whether it’s the Time or the Sun Trigger.
