Automation with variable trigger
I’ve got a dehumidifier that I want to turn off when it reaches a certain level, but that level is dependent on the humidity of the floor above it. (i.e. if its 33% humidity upstairs, running the dehumidifier 100% will NEVER get it less than 3% above that value).
Here’s what I have for that automation so far, but its reported as invalid.
- alias: basementDryEnough
  - below: '{{state_attr("climate.downstairs_tstat", "current_humidity")|float+4}}'
    entity_id: sensor.basementdehumidifier_am2301_humidity
    platform: numeric_state
  condition:
    condition: and
    conditions:
    - condition: template
      value_template: '{{ states.sensor.basementdehumidifier_am2301_humidity.state
        < (state_attr("climate.downstairs_tstat", "current_humidity")|float +4) }}'
  - data:
      payload: 'OFF'
      topic: basementDehumidifier/cmnd/POWER
    service: mqtt.publish
  - data:
      entity_id: climate.downstairs_tstat
      fan_mode: auto
    service: climate.set_fan_mode
Use a template trigger. You already have the correct template but you’re using it as a cond for some reason. Just move that up in to a template trigger and get rid of the condition block.
Alright, I’ll give that a try. Will report back.
So this is what I’ve written, but it still doesn’t seem to be firing.
condition: []
- data:
    payload: 'OFF'
- data:
    fan_mode: auto
Can’t see the full template in your post, can you re-paste?
Sorry about that. Should be updated now.
I’ve had to reorder it a bit so it makes sense in my brain, but this should be right…
- id: 5c4e53f3d1f44577841633cc4d85d186
    platform: template
    value_template: >
      {{ states('sensor.basementdehumidifier_am2301_humidity')|int
        < (state_attr('climate.downstairs_tstat' , 'current_humidity')|int + 4) }}
    - service: mqtt.publish
        payload: 'OFF'
    - service: climate.set_fan_mode
        fan_mode: auto
Once you’ve pasted it in and restarted, make sure the automation is on. Let me know :slightly_smiling_face:
Out of curiosity, why int and not float? considering the values im getting are decimal numbers (i.e. 38.4%)
You can use floats if you want, I just tend to round everything to ints.
Ah ok. I’ve got it working now. Thanks for the help!
No worries, please mark as solved :+1:
