Hi guys, I need some help I would like to make an automation starting from this wifi sensor from not connected to connected.
to open a door.thank you this is the sensor
{{ states('sensor.stk_lx1_wifi_connection') }}
What are the states of this sensor? Get these from Developer Tools / States. Are you sure it’s not a binary sensor?
How does HA open your door?
With answer to those, I would have thought you could create an automation via the UI fairly easily, but come back here if you get stuck.
Open the door with shelly1v3
Set a State Trigger looking for your wifi connection going To connected or whatever the actual state is.
Ignore the conditions, and set an Action to operate your Shelly (either Call Service / Turn On; or something under Device — you’ve not given nearly enough information to help further).
alias: prova
description: ""
- platform: state
entity_id:
- sensor.stk_lx1_wifi_connection
to:
- Home&Life SuperWiFi-DBCD.EXT1
condition: []
- service: light.turn_on
data: {}
entity_id: light.led
mode: single
That’s how I fixed it, thanks for all the help.
