Automation - WLED. Capture data and restore after automation
I have been trying to get this to work for a few days now and I continue to run into issues.
I have 1 LED strip being controlled by WLED. My goal is to have it change to a preset when it detects my phone is charging. Will run for 10 secs and return to the state it was in.
I have created 1 automation and 2 scripts.
Script one: Captures the brightness, color and effect.
alias: WLED_Current_Data
sequence:
  - service: input_text.set_value
    data_template:
      entity_id: input_text.original_brightness
      value: "{{ state_attr('light.esb8266_no_strip', 'brightness') | default(255) }}"
    data_template:
      entity_id: input_text.original_rgb_color
      value: >-
        {{ state_attr('light.esb8266_no_strip', 'rgb_color') | default([255,
        255, 255]) | tojson }}
    data_template:
      entity_id: input_text.original_effect
      value: "{{ state_attr('light.esb8266_no_strip', 'effect') | default('') }}"
The second script is to restore the LED Stip based off what script one captures.
alias: Restore_WLED_Settings
sequence:
  - service: light.turn_on
    data_template:
      entity_id: light.esb8266_no_strip
      brightness: "{{ states('input_text.original_brightness') | default(255) | int }}"
      rgb_color: >-
        {{ states('input_text.original_rgb_color') | default('[255, 0, 0]') }}
        # Default color
      effect: "{{ states('input_text.original_effect') | default('Fade') }}"
Here is my automation
alias: Phone Charging
description: When phone is charging
  - platform: state
    entity_id: sensor.le2127_battery_state_2
    to: charging
condition: []
  - service: script.turn_on
    entity_id: script.WLED_Current_Data  # Corrected script entity ID
    data_template:
      brightness: >-
        {{ state_attr('light.esb8266_no_strip', 'brightness') | int(default=255) }}
      rgb_color: "{{ state_attr('light.esb8266_no_strip', 'rgb_color') }}"
      effect: "{{ state_attr('light.esb8266_no_strip', 'effect') }}"
  - device_id: c317f52b9f515e77f8fb61265acf21e2
    domain: select
    entity_id: cd727352b07b272c599a57f0a402d192
    type: select_option
    option: Phone charging
  - delay:
      seconds: 10
    entity_id: script.Restore_WLED_Settings  # Corrected script entity ID
mode: single
Wondering if I am thinking of this wrong but this seems to be more of a hassle than I thought it would be lol. Ive heard some mention to use scenes but I do not have any preloaded settings I keep this strip at. I like to change to my liking lol.
You can create scenes on the fly to store your WLED light state then restore it after displaying your preset.
See: https://www.home-assistant.io/integrations/scene/#creating-scenes-on-the-fly
Interesting… Ty.
Ill take a look at that now
