Hello everyone,
So I’m trying to get my lights to turn on when i wake up. (When my alarm goes off in the morning)
I got so far to send a request from iOS shortcuts to Home Assistant at which time the automation or script should be triggered.
If I look in my logbook, you will see that everything (seems to) work fine.
So in this case, at 23:41, multiple lights should go on.
However, nothing happens.
I have just created the script with the UI, so nothing special about that. But just to be sure, this is the script:
If I try to run the script manually, everything works. Just not at the time that is provided.
In another topic, i saw the advice to look if the system clock and so the timezone is set correctly. And this is the case. From the system clock and from Home Assistant itself.
I’ve been struggling with this for hours, but I really can’t figure it out.
Can someone help me?
Thanks in advance!
