I’m trying to get my two lights to turn on when I open my basement (stairwell) door and if there is no motion after 5 minutes, turn them off.
The tricky part is if the door isn’t closed when the person is going down the stairs, it will mess up the automation.
The additional tricky part is I have a nighttime timer to do a similar function at a different time.
My automation definitely doesn’t follow optimal logic, so in the good spirit of finding a better solution feel free to roast this one.
For context, tradfri motion sensor 2 is hidden about halfway down the stairs.
Basement motion sensor is at the very opposite of the room from the steps and may or may not sense motion if someone were to go down the stairs depending on whether they make a right or left immediately after.
The way you have your conditions configured both lights have to be off for the actions to run. Logical combination conditions like and, or, and not apply only to the conditions nest beneath them… Your or only has one clause, meaning that clause must be true to pass. If you’re not married to the use of Device conditions, State conditions have a built-in OR ability by just adding match: any for the condition’s configuration.
Can you explain what you mean? There’s nothing in this automation that says the door must be closed close.
You may be better off creating a binary sensor group for all the motion sensors, then use that in your wait (or better yet a separate trigger).
alias: Stairwell Door Open Daytime
description: ""
- type: opened
platform: device
device_id: 3bd2cf73c26e6e44f6878ef15d661417
entity_id: binary_sensor.basement_door_sensor
domain: binary_sensor
condition:
- condition: time
after: "06:00:00"
before: "16:00:00"
weekday:
- mon
- tue
- wed
- thu
- fri
- sat
- sun
- condition: state
entity_id:
- light.stairwell_light
- light.basement_dimmer_2
match: any
state: "off"
- type: turn_on
device_id: f5b60f3b9de077d19b2fc6c75f6b643e
entity_id: light.basement_dimmer_2
domain: light
brightness_pct: 80
- type: turn_on
device_id: 2a52cd967002bee7554f86fde2fc7a58
entity_id: light.stairwell_light
domain: light
- wait_for_trigger:
- platform: state
to: 'off'
entity_id: binary_sensor.basement_motion_group
for:
hours: 0
minutes: 5
seconds: 0
- service: script.turn_off_basement_2
data: {}
mode: single
What I meant by the door was, when someone opens the door, it triggers this automation to turn things on. However, if someone opens the door, then closes the door, goes downstairs and then runs back up (like to grab a soda from the fridge or a forgotten item) when they open the door the automation will kick the lights back on.
This makes sense, I will give it a shot cause I’m not 100% sure I know how to create that but I think I should be able to figure it out.
When it comes to the binary sensor group, which option would that be in the visual editor? I’m currently trying “state” and typing in the two attributes to it.
I don’t know if understand the question… You do not create the binary sensor group in the Automation editor, you do it in the Helper menu.
If you’re asking how to use the group after it’s created… In the Wait for trigger, add a trigger, select “State” from the drop down. In the Entity ID field type in the name or entity ID of the group sensor. Leave the Attribute field blank. Type "on" in the From field and "off" in the To field. Set the duration.
