I want to switch on a light when I enter my home when it’s dark.
The trigger is ‘binary_sensor.garagepoort_gesloten’, the gate that opens (state on to off) in my garage.
It should also be dark, so I have this as condition (brightness below 20).
In the garage I have a motion sensor.
To determine the direction (the light must not be switche on when I left my home), I have the gate as trigger and the wait_for_trigger for the motion sensor.
alias: Switch on light when entering home
description: ''
- platform: state
entity_id: binary_sensor.garagepoort_gesloten
to: 'off'
condition:
- condition: numeric_state
entity_id: sensor.lightsensor_illuminance_lux
below: '20'
- wait_for_trigger:
- platform: state
entity_id: binary_sensor.motionsensor_garage_occupancy
to: 'on'
continue_on_timeout: true
- service: switch.turn_on
entity_id: switch.light_keuken_indirect
mode: single
When I enter at night, the light switches on, so that works.
Unluckely, this afternoon I came in and the light was also triggered to switch on.
I had a look in the automation and found:
Yes, it’s explained in Wait Timeout. Basically, you need to add a timeout value (there’s none by default).
You will need to change continue_on_timeout to false so that if the waiting time exceeds the timeout value it will not proceed to the service call to turn on the light.
For future reference, should you ever want to do one thing if wait_for_trigger is triggered and something different if it times out, here’s some code that demonstrates how to do that:
- wait_for_trigger:
- platform: state
to: 'on'
timeout: '00:05:00'
- choose:
- conditions: "{{ wait.trigger == none }}"
sequence:
- service: notify.persistent_notification
title: 'Wait for motion timed out.'
message: 'Timed out after 5 minutes.'
default:
title: 'Wait for motion triggered.'
message: 'Motion detected within 5 minutes.'
It sends different notifications depending on whether there was a trigger or a timeout (obviously you would replace the notifications with whatever service calls you require).
