Automation works in dev tools, not in yaml
I have an automation that changes settings on my z-wave thermostat. When the temp gets below 69F, it changes to heat, and sets the target temp to 69F. When it is triggered it will change the hvac_mode, but not the temp. However if I execute it via the dev tools with Call Service (see below), it works fine. I am kind of at a loss for how to troubleshoot it next. Any ideas for what to check would be appreciated. Thanks!
- alias: 'Turn on heat'
    platform: template
    value_template: "{% if states.sensor.honeywell_th8320zw1000_touchscreen_thermostat_temperature.state | float < 69.0 %} true {% endif %}"
    - service: climate.set_temperature
        entity_id: climate.honeywell_th8320zw1000_touchscreen_thermostat_mode
        temperature: 69
    - service: climate.set_hvac_mode
        hvac_mode: heat
Screen Shot 2020-09-18 at 1.22.56 PM
Change the Template Trigger to:
    value_template: "{{ states('sensor.honeywell_th8320zw1000_touchscreen_thermostat_temperature') | float < 69.0 }}"
Actually, that’s just a numeric state trigger, there’s no need for any templating at all.
    platform: numeric_state
    entity_id: sensor.honeywell_th8320zw1000_touchscreen_thermostat_temperature
    below: 69
Yes, the template will work, but it’s overly complicated for such a simple trigger.
Moreover, why is an automation monitoring a thermostat’s ambient temperature and then setting the thermostat’s target temperature and turning on heating. Seems to me a typical thermostat can do all that on its own.
It’s…my hobby?
In case anyone comes here looking for answers, none of these fixed my issue and I am not sure what the problem was but breaking out the second service change into its own automation accomplished the goal.
Your hobby would benefit from an understanding of how a climate entity works. It would spare you the trouble of creating unnecessary automations. However, apparently nothing suggested helped so I imagine this latest suggestion won’t either. Good luck to you.
