I have an automation that looks like it only works once.
The automation should turn on one light at 20:00 every day, as long as someone is home. Turning the light on manually in HA works properly.
The first time, it turns on the light just fine, everything works as it should. The next day, it does not turn on the light.
When I check the log, it says that it has been triggered and that it has run all the way through. Everything looks OK.
The automation is terribly simple
alias: Paviljong - on
description: ''
- platform: time
at: '20:00:00'
condition:
- condition: state
entity_id: group.familien
state: home
- type: turn_on
device_id: ca481ee412028d882f9a52db180fef2a
entity_id: light.lys_paviljong
domain: light
brightness_pct: 82
mode: single
If I edit something on the automation (eg change the brightness), it works once again - but not the next day.
I have tried to delete and recreate it, without any difference. Also tried to change from “device - turn on” to “call service - light turn on”. But no change.
Have also tried to remove conditioning in the automation to see if it made any change - but it behaves exactly the same.
The light is a Tuya light-string and the automation is created in the visual editor if it has any significance…
Any thoughts on what could be the reason why this is not running as it should every day?
