Automation.yaml nightmare [Solved]
automation.yaml nightmare
Still new to Home Assistant
Trying to make my first automation.yaml.
Unfortunately, it is not as expected.
automation:
    platform: time
    seconds: 10
    service: switch.turn_on
    entity_id: switch.light_in_the_office
Triggers the following error log:
2017-06-08 18:08:07
ERROR (MainThread) [homeassistant.config]
Invalid config for [automation]: [automation] is an invalid option for [automation].
Check: automation->automation. (See /home/homeassistant/.homeassistant/configuration.yaml, line 55).
Please check the docs at https://home-assistant.io/components/automation/
Line 55 is the line before Include automationyaml in configuration.yaml:
Have followed the examples from
But nevertheless it did not succeed.
Hope a sharp super user can figure out my mistakes and make me happy.
You need some "-"s…
 - alias: 'Refresh Owntracks'
     - platform: time
       minutes: '/15'
       seconds: 0
     - service: script.kick_owntracks
and remove automation: as it’s already specified in the config.yaml and add an alias:
do you have a seperate file named “automations.yaml” located in the same directory as the configuration.yaml file?
In the automations.yaml file do not include the “automation:” line. It is not needed and will break the config. Start with trigger.
Perhaps one step closer.
Automation: Removed
The new code:
- alias: 'Switch on automaticaly'
    - platform: time
      seconds: 10
      - service: switch.turn_on
        entity.id: switch.light_in_the_office
The new error log:
The following errors have been logged this session:
2017-06-08 18:46:16 ERROR (Thread-1) [homeassistant.util.yaml] while parsing a block collection
  in "/home/homeassistant/.homeassistant/automations.yaml", line 3, column 5
expected <block end>, but found '?'
  in "/home/homeassistant/.homeassistant/automations.yaml", line 6, column 5
2017-06-08 18:46:16 ERROR (MainThread) [homeassistant.bootstrap] Error loading /home/homeassistant/.homeassistant/configuration.yaml: while parsing a block collection
Still incomprehensible talk to me :frowning:
action should be under the t of trigger
and i think seconds: 10 should be seconds: ‘/10’ if you want to turn on the lamp every 10 seconds
yaml is very dependent on the spacing and it won’t work if it isn’t right :stuck_out_tongue:
It helped, now the lamp turns on after 6 seconds.
But automation 2 does not work?
- alias: 'Switch on automatically'
    - platform: time
      seconds: '/6'
automation 2:
    - platform: time
      seconds: '/12'
    - service: switch.turn_off
Error log
2017-06-08 20:27:21 ERROR (Thread-1) [homeassistant.util.yaml] while parsing a block collection
  in "/home/homeassistant/.homeassistant/automations.yaml", line 1, column 1
  in "/home/homeassistant/.homeassistant/automations.yaml", line 9, column 1
2017-06-08 20:27:21 ERROR (MainThread) [homeassistant.bootstrap] Error loading /home/homeassistant/.homeassistant/configuration.yaml: while parsing a block collection
Only Automation and not Automation 2 is displayet in frontend:
Format automation 2 the same as your first automation.
Start with the alais, then trigger.
    - platform: time
      seconds: '/6'
automation 2:
- alias: 'Switch off automatically'
    - platform: time
      seconds: '/12'
2017-06-08 20:45:37 ERROR (Thread-1) [homeassistant.util.yaml] while parsing a block collection
2017-06-08 20:45:37 ERROR (MainThread) [homeassistant.bootstrap] Error loading /home/homeassistant/.homeassistant/configuration.yaml: while parsing a block collection
remove “automation 2”
edit: perhaps an example from my config will help
  - alias: 'Turn Off Outside Lights'
      platform: sun
      event: sunrise
      - service: homeassistant.turn_off
        entity_id: group.outside_lights
      - delay: 0:01
  - alias: 'Turn On Outside Lights'
      platform: sun
      event: sunset
      offset: '-00:15:00'
      - service: homeassistant.turn_on
      - delay: 0:01
You can’t have automation 2: as automation has been specified in the config.yaml, please peruse the docs
Thank you very much
So drive my light show :slight_smile:
I was inspired by this example
TIME TRIGGER
Time can be triggered in many ways. The most common is to specify at and trigger at a specific point in time each day. Alternatively, you can also match if the hour, minute or second of the current time has a specific value. You can prefix the value with a / to match whenever the value is divisible by that number. You cannot use at together with hour, minute or second.
automation:
    platform: time
    # Matches every hour at 5 minutes past whole
    minutes: 5
    seconds: 00
automation 2:
    platform: time
    # When 'at' is used, you cannot also match on hour, minute, seconds.
    # Military time format.
    at: '15:32:00'
automation 3:
    platform: time
    # You can also match on interval. This will match every 5 minutes
    minutes: '/5'
    seconds: 00
:smiley: + ten chars :stuck_out_tongue:
