Hi there, I could not find an flexible way to use my hue dimmer switch with zigbee2mqtt so I smashed this automation together. I hope somebody finds it useful. I would appreciate proposals to enhance the automation - its not optimized at all - but it works.
Also: how do you handle your switch routines?
- alias: Hue Remote Switch 1
- platform: mqtt
topic: zigbee2mqtt/HueDimmerS1
condition:
condition: and
conditions:
- condition: template
value_template: '{{ trigger.payload_json.action|length > 0 }}'
value_template: "{{ (as_timestamp(now()) - as_timestamp(state_attr('automation.hue_remote_switch_1', 'last_triggered') | default(0)) | int > 1)}}"
#possible states
# on |up |down| off
# on-press
# on-hold
# on-hold-release
- service_template: >
{% set button = trigger.payload_json.action %}
{% if "hold" in button %}
{% set holding = true %}
{% else %}
{% set holding = false %}
{% endif %}
{% if "release" in button %}
{% set released = true %}
{% else %}
{% set released = false %}
{% endif %}
{% if "on" in button %}
{% set button = 1 %}
{% elif "up" in button %}
{% set button = 2 %}
{% elif "down" in button %}
{% set button = 3 %}
{% elif "off" in button %}
{% set button = 4 %}
{% else%}
{% set button = 5 %}
{% endif %}
{% set duration = trigger.payload_json.duration|float %}
{% if button == 1 and not holding %}
media_player.media_play_pause
{% elif button == 2 and not holding %}
media_player.volume_up
{% elif button == 3 and not holding %}
media_player.volume_down
{% elif button == 4 and not holding %}
media_player.media_next_track
{% elif button == 1 and holding and released %}
input_select.select_next
{% elif button == 2 and holding and released %}
media_player.media_previous_track
{% elif button == 3 and holding and released %}
input_select.select_previous
{% elif button == 4 and holding and released %}
homeassistant.turn_off
{% else %}
{% endif %}
data_template:
entity_id: >
{% else %}
{% endif %}
{% else %}
{% endif %}
{% else%}
{% endif %}
media_player.spotify
input_select.atmo
input_select.atmo
group.all_lights
{% else %}
{% endif %}
