Automation: zigbee2mqtt device updater
I made automation that checks updateable Zigbee devices from zigbee2mqtt bridge and asks you if you want to update them.
groups.yaml Place here all your zigbee2mqtt devices that can do OTA update
zigbee_updates:
  name: Zigbee device updates
  entities:
    - binary_sensor.0x000b57fffef2c3e6_update_available
    - binary_sensor.0x842e14fffe416ac5_update_available
    - binary_sensor.0x842e14fffefc7ffa_update_available
    - binary_sensor.0x842e14fffe415c1e_update_available
    - binary_sensor.0x842e14fffe415d7e_update_available
    - binary_sensor.0x842e14fffe43aaf8_update_available
    - binary_sensor.0x000d6ffffe54fd83_update_available
    - binary_sensor.0x000b57fffeebd210_update_available
    - binary_sensor.0x000b57fffed8366c_update_available
    - binary_sensor.0x842e14fffe41729d_update_available
    - binary_sensor.0x000d6ffffe09fda2_update_available
automations.yaml
- id: notify_if_zigbee_update
  alias: Notification- Alert That Zigbee device has updates
  initial_state: 'on'
  - hours: /4
    platform: time_pattern
  condition:
    condition: and
    conditions:
      # don't send notifications in night time
      - condition: template
        value_template: "{{ 8 < now().hour < 21 }}"
        value_template: >
          {% set ns = namespace(found=false) -%}
          {% for entity_id in states.group.zigbee_updates.attributes.entity_id -%}
            {% set parts = entity_id.split('.') -%}
            {% if is_state(entity_id, "on") -%}
              {% set ns.found = true -%}
            {% endif -%}
          {% endfor -%}
          {{ ns.found }}
    # change here your notification service
    - service: notify.home_assistant_notifications
        message: >
          {{ "\uD83D\uDCE6" }} Zigbee device(s):
          {%- for entity_id in states.group.zigbee_updates.attributes.entity_id -%}
            {%- set parts = entity_id.split('.') -%}
              {{ states[parts[0]][parts[1]].name | replace("_update_available","") }} {{ '\n' }}
            {%- endif -%}
          {%- endfor -%}
          has pending update(s).
          actions:
          - action: update_zigbeedevices
            title: Update
            destructive: true
          - action: ''
            title: Dismiss
- id: update_zigbeedevices
  alias: OTA update Zigbee devices
  - event_data:
    # change here your notification type
    event_type: html5_notification.clicked
    platform: event
    - repeat:
        # repeat for every entity in the list
        count: "{{ expand('group.zigbee_updates') | count }}"
        sequence:
          - choose:
              conditions: "{{ expand('group.zigbee_updates')[repeat.index].state == 'on' }}"
              sequence:
                - service: mqtt.publish
                    topic: zigbee2mqtt/bridge/ota_update/update
                    payload: "{{ expand('group.zigbee_updates')[repeat.index].entity_id.replace('binary_sensor.', '') | replace('_update_available','') }}"
                - delay: 5
Excelent project!
Thanks for sharing.
Interesting project. I am getting an error in - id: update_zigbeedevice
Invalid config for [automation]: Expected a dictionary @ data[‘action’][0][‘repeat’][‘sequence’][0][‘choose’][0][‘conditions’][0]. Got None. (See /config/configuration.yaml
I will work through fault finding but if you have any ideas please let me know. I am on HA Home Assistant 0.114.1
Cheers
Upgraded to Home Assistant 0.117.5 and no config error. Not fully tested updating yet, but over the first hurdle.
@gsmckenzie I’m on HA 0.177.2 and no config error. Update also works.
If you can, you can follow upgrading process over SSH with command:
mosquitto_sub -t zigbee2mqtt/#
I’m on HA 0.117.6 (and same for 0.117.5).
{{ expand(‘group.zigbee_updates’) | count }}
This template listens for the following state changed events:
  • Kohde : binary_sensor.0x680ae2fffe97ad47_update_available
  • Kohde : binary_sensor.0x680ae2fffea7e281_update_available
  • Kohde : binary_sensor.0xec1bbdfffe2de77b_update_available
  • Kohde : binary_sensor.0xec1bbdfffe8811cb_update_available
  • Kohde : binary_sensor.0xec1bbdfffe8812d5_update_available
  • Kohde : binary_sensor.0xec1bbdfffe9ebc14_update_available
  • Kohde : group.zigbee_updates
No config error but:
2020-11-13 19:30:51 ERROR (MainThread) [homeassistant.components.automation.notification_alert_that_zigbee_device_has_updates] Notification- Alert That Zigbee device has updates: Error executing script. Service not found for call_service at pos 1: Unable to find service notify/home_assistant_notifications
2020-11-13 19:30:51 ERROR (MainThread) [homeassistant.components.automation.notification_alert_that_zigbee_device_has_updates] While executing automation automation.notification_alert_that_zigbee_device_has_updates
File “/usr/src/homeassistant/homeassistant/components/automation/init.py”, line 426, in async_trigger
await self.action_script.async_run(
File “/usr/src/homeassistant/homeassistant/helpers/script.py”, line 1010, in async_run
await asyncio.shield(run.async_run())
File “/usr/src/homeassistant/homeassistant/helpers/script.py”, line 245, in async_run
await self._async_step(log_exceptions=False)
File “/usr/src/homeassistant/homeassistant/helpers/script.py”, line 253, in _async_step
await getattr(
File “/usr/src/homeassistant/homeassistant/helpers/script.py”, line 460, in _async_call_service_step
await service_task
File “/usr/src/homeassistant/homeassistant/core.py”, line 1398, in async_call
raise ServiceNotFound(domain, service) from None
homeassistant.exceptions.ServiceNotFound: Unable to find service notify/home_assistant_notifications
@mcpaha It seems that you havent setup a notification service.
I use html5 push notifications:
There are lot of different notifier services available, like discord.
