hello, I made automation triggered by state of input boolean and time condition :
automation:
- alias: 'turn on test'
platform: state
entity_id: input_boolean.timer
to: 'ON'
condition:
condition: time
after: '08:55:00'
service: input_boolean.turn_on
entity_id: input_boolean.output
the problem is, why automation not triggered at certain time (‘08:55’) if I turn on input_boolean.timer before ‘08:55’, let say at ‘08:50’?
How to solve it?
you need just a small change
automation:
platform: state
to: 'on'
condition:
condition: time
after: '08:55:00'
I do not think the suggestion from @ReneTode will solve your problem.
Try something like:
automation:
- platform: state
to: 'ON'
- platform: time
after: '08:55'
condition:
- condition: time
after: '08:55:00'
- condition: state
state: 'on'
Thanks for your support, so automation will check the time at ‘08:55’ and condition.
Another question, is state from a variable, let say sensor.alarm_time (value is 08:55) cannot be parsed into time trigger configuration?
platform: time
after: '{{ states(sensor.alarm_time) }} '
@Danielhiversen you are right i just saw his code and didnt read his question right.
but i think you need from: off to: on (but im not sure)
and dont you need condition: AND in your example?
@cyber.mocca no you cant use template values in after:
I’m not sure if we need to add “from:…” but I’m agree to use condition: and.
So, how to manage a system that need a user-defined time as time trigger?
look at the alarmclock topics here on the forum, i think they will be helpfull
I have tried creating alarm clock topic, but it doesnt work for me
The trigger is to parsing value template to now.time().srtftime(), but till the certain time that user defined, the message doesnt appeared
off course the message only appears when the alarm is triggered.
but you could add a second trigger in the automation, like @Danielhiversen showed.
condition: AND
is default, so you do not need to add that.
Yes, thanks for your suggestion. But till now, this code doesnt work for me.
Anything wrong with this?
input_slider:
alarmhour:
icon: mdi:timer
initial: 9
min: 0
max: 23
step: 1
alarmminutes:
icon: mdi:timer
initial: 0
min: 0
max: 55
step: 5
input_boolean:
alarmstatus:
name: Wake Me Up
initial: off
icon: mdi:alarm-check
alarmweekday:
initial: off
icon: mdi:calendar
platform: template
sensors:
alarm_hour:
friendly_name: 'Hour'
value_template: '{{ states("input_slider.alarmhour") | round(0) }}'
alarm_minutes:
friendly_name: 'Minutes'
value_template: '{{ states("input_slider.alarmminutes") | round(0) }}'
alarm_time:
friendly_name: 'Time'
value_template: '{{ states("sensor.alarm_hour") }}:{% if states("sensor.alarm_minutes")|length == 1 %}0{% endif %}{{ states("sensor.alarm_minutes") }}'
group:
default_view:
view: yes
entities:
- group.alarmclock
alarmclock:
name: Wake Me Up
entities:
- sensor.alarm_time
- input_slider.alarmhour
- input_slider.alarmminutes
- input_boolean.alarmstatus
- input_boolean.alarmweekday
automation
- alias: 'Wake Me Up'
platform: template
value_template: '{{ now.time().strftime("%-H") == states.sensor.alarm_hour.state and now.time().strftime("%-M") == states.sensor.alarm_minutes.state }}'
condition:
condition: or
conditions:
- condition: and
conditions:
- condition: state
entity_id: input_boolean.alarmstatus
state: 'on'
- condition: state
entity_id: input_boolean.alarmweekday
state: 'on'
- condition: time
weekday:
- mon
- tue
- wed
- thu
- fri
- condition: and
conditions:
- condition: state
state: 'on'
- condition: state
state: 'off'
service: notify.notify
message: 'Good morning. Time to Wake Up!'
title: ""
i think that strftime("%-H") should be strftime("%H")
same for M
Yes, but still not working…
I think because automation triggered by template changing, not time.
Any suggestion?
in the template value you compare a string with a rounded float.
“09”==9 will never be right
{{ (now.time().strftime("%H")|int == states.sensor.alarm_hour.state|int) and (now.time().strftime("%M")|int == states.sensor.alarm_minutes.state|int) }}
this could do it (at least that template comes to true)
I’ll try that, so my automation be like this :
automation:
platform: template
value_template: '{% if is_states("sensor.alarm_hour|int", "now.time().strftime("%H:%M")|int")}true{% endif %}'
condition:
condition: state
state: 'on'
service: persistent_notification.create
message: '{{states("sensor.alarm_time")}}'
title: "message"
the automation should work, the message not i think.
i think the message should be a value_template
Still dont work.
I’m confusing for that code, I changed trigger to time trigged every 5s.
And check condition, if true then action.
automation:
platform: time
hours: '*'
minutes: '*'
seconds: '/5'
condition:
conditions:
- condition: state
state: 'on'
- condition: template
value_template: '{% if is_state("sensor.alarm_hour|int", "now.time().strftime("%H:%M")|int")%}true{% endif %}'
message: '{{states.sensor.alarm_time.state}}'
title: "message"
cyber.mocca:
hours: '*'
minutes: '*'
I don’t think this is accepted. If you don’t want to specify hours or minutes, just leave them out.
data_template:
title: "message"
And for this, I took out 2 indents in front of message
and title
, and changed data
to data_template
So in total, it shoud look like this (with a few more indents removed):
automation:
platform: time
seconds: '/5'
condition:
conditions:
- condition: state
state: 'on'
data_template:
title: "message"
Thanks for your correction about time platform that dont need hours and minutes, but the problem is the condition.
I think the condition template doesnt return “true” for that code.
And still not work if I changed to this :
'{% if is_state("sensor.alarm_hour|int", "sensor.worldclock_sensor|int")%}true{% endif %}'
any idea to compare value of template and current time that can return “true” value?
I’m not sure about the second example, but you have too many double quotes going in the first one, cutting your strings short unintentionally. Try this:
value_template: >
{% if is_state("sensor.alarm_hour|int", "now.time().strftime('%H')|int")%}true{% endif %}
By putting the template on a new line with >
, you can omit the single quotes and use them for your time format instead. And also, you can’t convert something in the format %H:%M
to an integer, so just use %H
