I see an automation0.yaml in my config folder :
It seems an old (corrupt) file. I can delete it, but watchman still gives me errors in that file ?
Is there another place I have to delete it ?
Have you opened it to see what’s there and if so is it important?
if no then just delete it.
If you aren’t sure just rename it to automations0.yaml.old (or something) and restart to see if anything you need stops working.
if not delete it.
It seems the file is back…
What means the ‘9’ ?
Never mind, did the same trick as before and it’s ok.
