I have HAS ( v2022.6.1) running on docker. Last night I rebooted in docker (with container) and it crashed with an error 500. I did some investigations, moved the configuration.yaml etc and finally I discovered the problem had to do with the USB port. I had two USB ports (one for the DSMR and one for the 433Mhz device). I removed the 433 Mhz device because I do not use it anymore. The /dev/ttyUSB1 port then changed to /dev/ttyUSB0. After modifying the container resources in portainer (changed USB1 to USB0) Home Assistant was working again (after a some sleepless nights:)). But now I faced another problem. Everything is working again great but my Automations and scripts are empty in the HAS interface. The blueprint and scenes tab are not empty. I tried all kind of tips but untill now no succes. I checked my YAML with HAS and there where no errors. Also the log is showing no errors. Any tips would highly appreciated!
automations.yaml file (snippet)
# Configure a default setup of Home Assistant (frontend, api, etc)
default_config:
# Text to speech
tts:
- platform: google_translate
script: !include scripts.yaml
scene: !include scenes.yaml
automations.yaml (snippet)
- id: '1648803417878'
alias: Livingroom lights
description: lights on
- platform: sun
event: sunset
offset: '-900'
- platform: device
device_id: dedad078b161d406948475fed71dexxx
domain: zwave_js
type: event.value_notification.central_scene
