I’ve been having a problem for a few months now but I can’t figure it out and couldn’t find any information, if I didn’t search properly I apologize in advance.
Then the problem. The system functioned well and I always do all Homeassistant core/os updates. I also did that in December and after that update all automations suddenly disappeared. When I looked in the automations.yaml file, the contents were still there.
But somehow the system no longer sees the automations. I finally decided to roll back the update and have left it that way for the past few months. Because I want to do the update now, I’m still looking for a solution. Does anyone have an idea?
You call a rollback to “Prior” December 22 version, for “few month” ?
I suggest you copy your views/dashboards automation.yaml, and other yaml-files/settings, and reinstall a new(latest version) of HA, and install your integrations again(latest) etc etc.
Trying to upgrade from a " prior December 2022 " is NOT a trivial task, AND you will need to spend alot time reading release notes for all "braking changes etc. etc. And most likely wont succeed anyway
Thanks for the reaction, as you wil understand by now i am not an expert
But I have done te reinstall the way you advised today. And all went wel. All the integrations and dasbboards are working, the only problem that remains is the problem with the automations.
the strange thing is that when i make a new automation that this automation is added tot the automations.yaml file but disappears the same way in homeassistant and can’t be used.
Copy the txt in automation.yaml and paste it here BUT please place it “between” 3-backticks
Point 11 in below doc
ALSO, check your logfiles, and provide “snippets” of relevant info/warnings/errors (in 3 backticks)
And while you are getting “warm” please also provide your configuration.yaml( in 3 backticks)
Thanks for your time and response, I really appreciate it.
The log files show that there is a problem loading the automations. Hopefully this will provide information about the cause. I will also send the config and automations files.
My Homeassistant is installed on a mini pc (x86/64):
Home Assistant 2023.8.4
Supervisor 2023.08.1
Operating System 10.5
Frontend-versie: 20230802.1 - latest
Logboek Details (FOUT)
Logger: homeassistant.setup
Source: setup.py:207
First occurred: 12:05:45 (1 occurrences)
Last logged: 12:05:45
Unable to set up dependencies of default_config. Setup failed for dependencies: automation
Source: setup.py:225
First occurred: 12:05:44 (1 occurrences)
Last logged: 12:05:44
Setup failed for automation: Invalid config.
Logger: homeassistant.config
Source: loader.py:879
Unknown error calling automation config validator
File "/usr/src/homeassistant/homeassistant/config.py", line 864, in async_process_component_config
await config_validator.async_validate_config(hass, config)
File "/usr/src/homeassistant/homeassistant/components/automation/config.py", line 261, in async_validate_config
await asyncio.gather(
File "/usr/src/homeassistant/homeassistant/components/automation/config.py", line 242, in _try_async_validate_config_item
return await _async_validate_config_item(hass, config, False, True)
File "/usr/src/homeassistant/homeassistant/components/automation/config.py", line 210, in _async_validate_config_item
automation_config[CONF_ACTION] = await script.async_validate_actions_config(
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 264, in async_validate_actions_config
return await asyncio.gather(
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 315, in async_validate_action_config
choose_conf[CONF_SEQUENCE] = await async_validate_actions_config(
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 279, in async_validate_action_config
config = await device_action.async_validate_action_config(hass, config)
File "/usr/src/homeassistant/homeassistant/components/device_automation/action.py", line 54, in async_validate_action_config
return await async_validate_device_automation_config(
File "/usr/src/homeassistant/homeassistant/components/device_automation/helpers.py", line 55, in async_validate_device_automation_config
platform = await async_get_device_automation_platform(
File "/usr/src/homeassistant/homeassistant/components/device_automation/__init__.py", line 174, in async_get_device_automation_platform
integration = await async_get_integration_with_requirements(hass, domain)
File "/usr/src/homeassistant/homeassistant/requirements.py", line 52, in async_get_integration_with_requirements
return await manager.async_get_integration_with_requirements(domain)
File "/usr/src/homeassistant/homeassistant/requirements.py", line 148, in async_get_integration_with_requirements
integration = await async_get_integration(self.hass, domain)
File "/usr/src/homeassistant/homeassistant/loader.py", line 879, in async_get_integration
raise int_or_exc
TypeError: exceptions must derive from BaseException
Configuration.yaml
# Configuratie instellingen
default_config:
http:
ssl_certificate: /ssl/fullchain.pem
ssl_key: /ssl/privkey.pem
# Text to speech
tts:
- platform: google_translate
group: !include groups.yaml
script: !include scripts.yaml
scene: !include scenes.yaml
light:
- platform: group
entities:
- light.keukentafel1
- light.keukentafel2
- light.keukentafel3
- platform: group
entities:
- light.links_achter_buiten
- light.links_achter_binnen
- light.links_voor_buiten
- light.links_voor_binnen
- light.rechts_achter_buiten
- light.rechts_achter_binnen
- light.rechts_voor_buiten
- light.rechts_voor_binnen
- platform: group
entities:
- light.lamp21_gang
- light.lamp22_gang
- light.lamp1_gang
- platform: group
entities:
- light.achterdeur_lamp
- light.garagedeur_lamp
- light.schuur_lamp
#google assisstent
google_assistant:
project_id: homeassistent-9cd1a
service_account: !include HomeAssistentGoogle.json
report_state: true
frontend:
themes: !include_dir_merge_named themes
#Powercalc
powercalc:
logger:
default: warning
logs:
custom_components.powercalc: debug
Automations.yaml
- id: '1628935485891'
alias: A|U keuken
description: ''
use_blueprint:
path: brent/zha-ikea-tradfri-wireless-dimmer-with-options-for-custom-actions.yaml
input:
remote1: 7d38234176633a8899c80f89cd6a9251
lights:
entity_id:
- light.keukenverlichting
off_long_custom: true
on_long_custom: true
button_on_long:
- device_id: 9a2633fe290b5606298cf94b748726b7
domain: light
entity_id: light.keukentafel1
type: brightness_increase
- device_id: 2973f9647a06068d73f05475b8d9743a
domain: light
entity_id: light.keukentafel2
- device_id: 4a98fd85b8896a539b1e280eec702d9a
domain: light
entity_id: light.keukentafel3
button_off_long:
domain: light
type: brightness_decrease
domain: light
domain: light
- id: '1628940392256'
alias: vijverlicht bij sunset
description: ''
use_blueprint:
path: CyanAutomation/lights_on_at_sunset.yaml
input:
target_light:
device_id: 71b8fcb789fbafc69db147ed0b83dc01
target_brightness: 5
- id: '1628974304103'
alias: Vijverlicht_uit
description: ''
- platform: time
at: '23:59'
condition: []
- type: turn_off
entity_id: light.vijver
domain: light
mode: single
- id: '1629456697115'
alias: A|U Woonkamer
description: ''
use_blueprint:
input:
remote1: 777787a393a6223ea6bd3bfa78e51891
lights:
entity_id: light.woonkamerverlichting
on_short_custom: false
button_on_long:
- device_id: b0688da3bd916eef074eaff1f478c170
domain: light
entity_id: light.links_achter_binnen
- device_id: 0856f07546d8ccc6c3bdd2bde79024c2
domain: light
entity_id: light.links_achter_buiten
- device_id: 01bd25681328762a5005c5a182db6b99
domain: light
entity_id: light.links_voor_binnen
- device_id: 7ef151a08348cd4be0f6985d83473789
domain: light
entity_id: light.links_voor_buiten
- device_id: 60083bfb79ca9fc09b78693edcef9102
domain: light
entity_id: light.scenes
- device_id: f16422d0c55537080f6d3e398794aaac
domain: light
entity_id: light.rechts_achter_buiten
- device_id: a671f352371cf8a9d72d873bd258b489
domain: light
entity_id: light.rechts_voor_binnen
- device_id: c5845e8ba7734002b93be5c2f033f9a3
domain: light
entity_id: light.rechts_voor_buiten
button_off_long:
domain: light
domain: light
domain: light
domain: light
domain: light
domain: light
domain: light
domain: light
button_on_short:
- device_id: ''
domain: ''
entity_id: ''
- id: '1629558814520'
alias: A|U Tuinverlichting
description: ''
use_blueprint:
input:
remote1: 3094ea8dea4ae327002c20f16cc2db80
lights:
device_id:
- cf06dd505911b9de5a6afa799d508330
- 17520dcd831f406382b217019c812a9a
- 48889ce4a860eafd8a94108d2ba24be7
off_short_custom: false
button_on_long:
- device_id: cf06dd505911b9de5a6afa799d508330
domain: light
entity_id: light.achterdeur_lamp
- device_id: 17520dcd831f406382b217019c812a9a
domain: light
entity_id: light.schuur_lamp
- device_id: 48889ce4a860eafd8a94108d2ba24be7
domain: light
entity_id: light.garagedeur_lamp
button_off_long:
domain: light
domain: light
domain: light
- id: '1629632638386'
alias: Espresso aan
description: ''
- device_id: 686bc6e28cfabbab5e2cbbcbcb5284c3
domain: zha
platform: device
type: remote_button_short_press
subtype: turn_on
condition: []
- type: turn_on
device_id: 185959104d24c54f5f4685c6140310a1
entity_id: switch.espresso_switch_2
domain: switch
- type: turn_on
device_id: 3f94401c84e2b9b379f9a2e75ea3604c
entity_id: switch.bonenmaler
domain: switch
mode: single
- id: '1629632720974'
alias: Espresso uit
description: ''
domain: zha
platform: device
subtype: turn_off
condition: []
- type: turn_off
domain: switch
- type: turn_off
domain: switch
mode: single
- id: '1629632790244'
alias: hifi aan
description: ''
- device_id: 20c3a17b693da352eae84b4eac54a268
domain: zha
platform: device
subtype: turn_on
condition: []
- type: turn_on
device_id: 3ea0db76650ae6c4bd9f3b269746b58e
entity_id: switch.frient_a_s_splzb_131_switch_6
domain: switch
mode: single
- id: '1629632851869'
alias: hifi uit
description: ''
domain: zha
platform: device
subtype: turn_off
condition: []
- type: turn_off
domain: switch
mode: single
- id: '1647276645031'
alias: voordeurslot open knop
description: ''
- device_id: 8b05df4882ac401f1236c4542b5b0908
domain: zha
platform: device
subtype: remote_button_short_press
condition: []
- service: script.deur_open
data: {}
mode: single
- id: '1657208579710'
alias: A|U woonkamer
description: ''
use_blueprint:
input:
lights:
entity_id:
- light.woonkamerverlichting
button_on_short:
- device_id: ''
domain: ''
entity_id: ''
- id: '1657209116266'
description: ''
use_blueprint:
input:
lights:
entity_id:
button_on_long:
domain: light
domain: light
domain: light
domain: light
domain: light
domain: light
domain: light
domain: light
button_off_long:
domain: light
domain: light
domain: light
domain: light
domain: light
domain: light
domain: light
domain: light
- id: '1659438363743'
alias: Voordeur schakelaar
description: ''
use_blueprint:
input:
button_on_short:
- condition: state
entity_id: binary_sensor.lumi_lumi_sensor_magnet_aq2_ced7ec07_on_off
state: 'off'
- delay:
hours: 0
minutes: 0
seconds: 30
milliseconds: 0
- device_id: ''
domain: ''
entity_id: ''
remote1: a866b6ae71048270e45a008f4798b408
button_off_short:
- service: script.status_naar_afwezig
data: {}
on_short_custom: true
off_short_custom: true
- id: '1659531925818'
alias: Schakelaar voordeur
description: ''
use_blueprint:
input:
button_on_short:
- service: script.status_naar_thuis
data: {}
button_off_short:
- service: script.deur_sluiten
data: {}
button_off_long:
data: {}
- id: '1665129168708'
alias: vissen voeren 10 uur
description: ''
- platform: time
at: '10:00:00'
condition: []
- service: script.vissen_voeren
data: {}
mode: single
- id: '1665129268441'
alias: Vissen voeren 17 uur
description: ''
- platform: time
at: '17:00:00'
condition: []
data: {}
mode: single
- id: '1683386853540'
alias: vissen voeren 13.00
description: ''
- platform: time
at: '13:00:00'
condition: []
data: {}
mode: single
- id: '1690530092871'
alias: Camera achtertuin aan bij zonsondergang
description: ''
- platform: sun
event: sunset
offset: 0
enabled: true
condition: []
- type: turn_on
device_id: ffd7c8384aee27287e985854423b9d72
entity_id: switch.camera_achtertuin_motion_detection
domain: switch
mode: single
Hi, welcome to the forum!
It’s not a browser cache issue or having multiple tabs with your HA open?
I would try to comment out every automation, then restart.
And every time uncomment one automation and restart again.
thanks Giel for your contribution,
I did something similar. I deleted all the automations in the automations.yaml, restarted and made a new automation in HA.
Although the automations.yaml contained this new automation, it was not loaded en not visible in HA. I would therefore I think that the problem is not in the automations.yaml file?
Thanks Nick for your suggestion.
unfortunately this is not the case.
Did you have any error when you restarted HA (with empty automations.yaml
Did you make this trough the UI?
no, i didn’t have any errors when i restarted. Except for the error in the log which I included above and states that de automations are not available.
yes, i made the automation through the UI.
So you still have this error when you empty your automations.yaml
yes, also with an empty automations.yaml I get this errors.
Thanks everyone for contributing to a solution. I just found the problem. It turned out that a blueprint I was using an automation gave me a problem. Removing this blueprint (for ikea switch) led to me being able to see all automations again. So now just find a solution for this blueprint.
