Automations: Condition Attribute state not working
trying to trigger automation only when driving my car. I have a trigger when entering a zone.
I am checking if my mobile is connected with car via bluetooth:
condition: state
entity_id: sensor.mi_6x_polaczenie_bluetooth
attribute: connected_paired_devices
state: "74:D7:CA:AD:30:4C (Toyota Touch)"
Unfortunately when I check condition in GUI via test button, I always get Condition did not pass.
I was checking state of the attribute in Developpers tools with
{{ state_attr('sensor.mi_6x_polaczenie_bluetooth','connected_paired_devices') }}
and got above attribute as result.
What am I doing wrong with my automation?
Regards,
Maciek
Developpers tools
 {{ '74:D7:CA:AD:30:4C (Toyota Touch))' in state_attr('sensor.mi_6x_polaczenie_bluetooth', 'connected_paired_devices') }}
Perhaps I was not clear enough.
On DevTools all works fine. It is just automation I have problem with.
Thanks. Tried value_template before, but it did not work, not work, not sure if it matters that attribute value is more than just MAC?
I think the automation should look something like this, of course with your own trigger and action.
The condition should be like this, to my best knowledge
description: "test automation"
mode: single
  - platform: state
    entity_id:
      - input_boolean.aa_test_boolean
condition:
  - condition: template
    value_template: >-
  - device_id: b81f18d9f8a302b925c324f95ce05f45
    domain: button
    entity_id: button.530e_flash_lights
    type: press
The Test button has a known bug that causes it to fail when testing Template Conditions. Until it’s fixed, I suggest you don’t rely on it to test your Template Conditions.
FWIW, there was a PR recently submitted to fix it but, due to some issues, it hasn’t been accepted yet.
    sensors:
      in_my_car:
        friendly_name: "Connection to the car "
        value_template: >
            {% if "50:4F:B5:07:9C:CA (MB-7079CDA)" in state_attr('sensor.sm_g975f_bluetooth_connection', 'connected_paired_devices') -%}
               on
            {% else -%}
               off
            {% endif -%}
Automations
platform: state
entity_id:
  - sensor.in_my_car
to: "on"
Thanks, I didn’t know IT.
Thanks a lot!
For the record, you didn’t need to create a Template Sensor to solve the problem you originally reported.
automation
mode: single
  - platform: numeric_state
    entity_id: sensor.sm_g975f_bluetooth_connection
    value_template: >
      {% if "74:D7:CA:AD:30:4C (Toyota Touch))" in
      state_attr(sensor.mi_6x_polaczenie_bluetooth',
          3
      {% else -%}
          1
      {% endif -%}
    above: 1
condition: []
    domain: button
    type: press
That’s a curious application of a Numeric State Trigger. It’s simpler to use a Template Trigger.
alias: example
    value_template: >
      {{ "74:D7:CA:AD:30:4C (Toyota Touch))" in state_attr(sensor.mi_6x_polaczenie_bluetooth', 'connected_paired_devices') }}
condition: []
  ... actions go here ...
