Hello, i created one automation with presence and it works perfect: when i connect to wifi light in my home entrance will be turned on. But because my phone connect to wifi when i am in elevator i added to automation dalay of 180 seconds. Was too much. I tried to 120 and 90 but it’s looks like system continue to turn on light after 180 seconds. I deleted line in automation conf about delay but it continue to turn on light later. SOmebody can tell me ife automation will be not saved only in automations.yalm?
Thank you
After modifying the automation, did you run either one of these commands?
Configuration > General > Reload Automations
Configuration > General > Restart
Sorry i forget to write, yes i made some days ago. Reloaded automations, system … computer , everything
Tonight i deleted all delay in all automations (was 2-3 more automations with delay) and now looks like everything is ok. Maybe i have to tell something because delay will be not pass to next automation?
For example in this case second automation was late but has not delay inside:
- id: RIENTRO MARYNA
alias: Rientro maryna
trigger:- entity_id: device_tracker.telefono_s9_maryna
platform: state
to: home
condition: []
action: - data:
entity_id: switch.cappa_cucina
service: switch.turn_on - delay: ‘60’
- id: ARRIVO MARYNA
alias: E arrivata maryna
platform: state
to: home
condition: []
action: - data:
entity_id: group.multimedia
message: è arrivata marina
service: tts.google_say
It’s impossible to see anything as you have not bothered with formatting your code!
Having said that, your delay is doing nothing if it’s the last action in an automation and actions do not flow from one automation to the next.
