After updating to Core version 2022.4.7 I have noticed many of the front end config values appear to be unpopulated. As an example below you can see the Tag value is missing. When I check automations.yaml I do see the tag ID, and the automation itself works fine.
Another issue I noticed was the actions itself were missing, I did update them and hit save, (had not realised it was an issue at this point). Iv mainly noticed this missing on automations related to Tags.
Digging further, when I access the automation from the tags menu option:-
The Action is still missing
However when I go into automations and open the same automation from there, the actions are visible
Here is my basic understanding:-
When you create an automation via a tag, it essentially creates an automation in your standard list of automations and these configs are stored in your automations.yaml.
As of now I see the right configs in my automations.yaml and the automation itself works as it should, the frontend however shows missing configs based on how you accessed the automation configurations itself.
I have also noticed, however unable to reproduce, duplication of automations when editing an automation and saving from the tags sections of home assistant.
If I’m able to reproduce this, I will update it here. until then any support would be appreiated.
Cheers
