I am new to Home Assistant and installed it last weekend on my RPi3.
Unfortunately, I have not been able to run any automation yet. Neither with the trigger time, nor with the change of action of the harmony hub. I have tried setting the automations by hand and also by using the editor. The automations are shown on the start page of hass.io and if i click them i can press the “run” button and in my case the light turns on.
I have created the automations in the automations.yaml, which is loaded by default using “automation: !include automations.yaml”.
This is what the automation editor creates and what’s not run (which I guess isn’t right):
Cleared Logs to get rid of anything that was there before.
Check Config -> No Problems found (tried just before pasting and it has an error because of my harmony automation, will check that if at least time triggered ones are running.
Pressed “restart HASS” in the configurator.
Automation still wasn’t run…
The automation won’t run till the time goes from 15:10 to 15:11, so to test it change the time to just after now (that would be 14:30 or so here in the UK) then reload the automation. You can test the action part by triggering manually using the UI click the automation and then click trigger.
