Automations Editor not bringing up entities to pick
For some reason the automation editor does not bring up the entities selection any more. When you call up services and pick the service you want, it used to then bring up all the entities available. That no longer happens. I have to switch to the YAML editor and manually put in the entities if I can remember them accurately. Is there some option I accidently turned off?? something get corrupted?? it works fine on my test platform? pls advise, thanks
To follow up, it looks like it just takes time (10 minutes?) after restart for the automation editor feature to “turn on”?? May be just due to the size of my HA?
How large is your HA setup? And what kind of device is running it?
Well I’m not sure how to size it but it’s about 40mb in the snapshot, some 380 lights, 50 or so automations so far, 30 motion sensors. Still have a lot more to do. Running on an Odroid
Its pretty consistent in that it takes 10-15 min after HA is fully restarted for the automation editor to have all it’s function.
