All my automations work fine in 2022.2.9 and prior however updating to 2022.3 or 2022.3.1 causes the automations to fail to load. I have pasted the log below. Appreciate any help troubleshooting this.
2022-03-04 08:51:46 ERROR (MainThread) [homeassistant.config] Unknown error calling automation config validator
File "/usr/src/homeassistant/homeassistant/config.py", line 819, in async_process_component_config
return await config_validator.async_validate_config( # type: ignore[no-any-return]
File "/usr/src/homeassistant/homeassistant/components/automation/config.py", line 126, in async_validate_config
await asyncio.gather(
File "/usr/src/homeassistant/homeassistant/components/automation/config.py", line 103, in _try_async_validate_config_item
config = await async_validate_config_item(hass, config, full_config)
File "/usr/src/homeassistant/homeassistant/components/automation/config.py", line 83, in async_validate_config_item
config[CONF_ACTION] = await script.async_validate_actions_config(
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 233, in async_validate_actions_config
return await asyncio.gather(
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 284, in async_validate_action_config
choose_conf[CONF_SEQUENCE] = await async_validate_actions_config(
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 260, in async_validate_action_config
conditions = await condition.async_validate_conditions_config(
File "/usr/src/homeassistant/homeassistant/helpers/condition.py", line 947, in async_validate_conditions_config
File "/usr/src/homeassistant/homeassistant/helpers/condition.py", line 931, in async_validate_condition_config
return await device_condition.async_validate_condition_config(hass, config)
File "/usr/src/homeassistant/homeassistant/components/device_automation/condition.py", line 51, in async_validate_condition_config
return await platform.async_validate_condition_config(hass, config)
File "/usr/src/homeassistant/homeassistant/components/zwave_js/device_condition.py", line 117, in async_validate_condition_config
node = async_get_node_from_device_id(hass, config[CONF_DEVICE_ID])
File "/usr/src/homeassistant/homeassistant/components/zwave_js/helpers.py", line 153, in async_get_node_from_device_id
if node_id is None or node_id not in client.driver.controller.nodes:
AttributeError: 'NoneType' object has no attribute 'controller'
2022-03-04 08:51:46 ERROR (MainThread) [homeassistant.setup] Setup failed for automation: Invalid config.
