from HA container i create ssh key and copy to host ,
ssh now working between HA to host without password.
I have scripts which managing dockers activities as upgrade container and basically what ever i need as part of the automation I need.
I manage to execute the script , see shell_command.yaml:
upgrade_mosquitto: ssh -i /config/ssh/id_rsa -o 'StrictHostKeyChecking=no' admin@NAS '. /share/HA/MyScripts/HA_Upgrade.sh mosquitto'
upgrade_homeassistant: ssh -i /config/ssh/id_rsa -o 'StrictHostKeyChecking=no' admin@NAS '. /share/HA/MyScripts/HA_Upgrade.sh homeassistant'
The script simply do :
docker pull new image ,stop current one , remove it and
run the docker-compose up -d <container_name>
#!/bin/sh
container_name=$1
docker=/share/CACHEDEV1_DATA/.qpkg/container-station/bin/docker
# Getting docker-compose dir
docker_compose_dir=/share/compose_file
Upgrade ()
$docker-compose stop $container_name
$docker-compose rm -f $container_name
$docker-compose up -d $container_name
cd $docker_compose_dir
$docker-compose pull $container_name
#throw to background
Upgrade &
Note , Im running the Upgrade part in background cause
when I execute the Upgrade for HA , i need to stop the container before.
Issues:
1.Everything is working fine - it upgrading all containers expect homeassistant ,
last step for docker-compose up -d not working .
I need to make the script run in background and preform the stop ,remove old container and start it.
I cant use docker command as is but i had to the full path of the docker ,
so instead of simple docker-compose pull
docker=share/CACHEDEV1_DATA/.qpkg/container-station/bin/docker
cd to/docker/compose/file
I tried adding . ./profile before executing but it doesn’t help.
