Hi all,
Getting an invalid configuration notice when I added a new automation. Not entirely sure what’s going on here so any assistance would be great. It seems to have caused one of my automations to not trigger (“Evening”). The new automation I’ve tried adding to my existing lighting.yaml config:
- alias: "Berto Leaving"
- platform: sun
event: sunrise
offset: '+00:10:00'
- platform: zone
entity_id: device_tracker.berto_iphone
zone: zone.home
event: leave
service: homeassistant.turn_off
entity_id: switch.living_room_lamp
The existing config which was working fine before adding this new entry was:
- alias: "Berto Wakeup"
platform: time
after: '05:45:00'
service: homeassistant.turn_on
- platform: sun
event: sunrise
offset: '+00:10:00'
- platform: zone
zone: zone.home
event: leave
- alias: "Evening"
platform: sun
event: sunset
offset: '-00:15:00'
- alias: "Sleeping"
platform: time
after: '01:30:00'
entity_id: group.all_switches
And the error I’m seeing is:
Jan 04 22:09:18 ha-ubuntu hass[7408]: 17-01-04 22:09:18 INFO (MainThread) [homeassistant.loader] Loaded automation.time from homeassistant.components.automation.time
Jan 04 22:09:18 ha-ubuntu hass[7408]: 17-01-04 22:09:18 INFO (MainThread) [homeassistant.loader] Loaded automation.sun from homeassistant.components.automation.sun
Jan 04 22:09:18 ha-ubuntu hass[7408]: 17-01-04 22:09:18 INFO (MainThread) [homeassistant.loader] Loaded automation.zone from homeassistant.components.automation.zone
Jan 04 22:09:18 ha-ubuntu hass[7408]: 17-01-04 22:09:18 INFO (MainThread) [homeassistant.bootstrap] Setting up automation
Jan 04 22:09:18 ha-ubuntu hass[7408]: 17-01-04 22:09:18 INFO (MainThread) [homeassistant.loader] Loaded sun from homeassistant.components.sun
Jan 04 22:09:18 ha-ubuntu hass[7408]: 17-01-04 22:09:18 ERROR (MainThread) [homeassistant.bootstrap] Attempt made to setup sun during setup of sun
Jan 04 22:09:18 ha-ubuntu hass[7408]: 17-01-04 22:09:18 ERROR (MainThread) [homeassistant.bootstrap] Component sun failed to setup
Jan 04 22:09:18 ha-ubuntu hass[7408]: 17-01-04 22:09:18 ERROR (MainThread) [homeassistant.bootstrap] Unable to prepare setup for platform automation.sun because dependency sun could not be initialized
Jan 04 22:09:18 ha-ubuntu hass[7408]: 17-01-04 22:09:18 INFO (MainThread) [homeassistant.core] Bus:Handling <Event call_service[L]: domain=persistent_notification, service_data=notification_id=invalid_config, title=Invalid config, message=The following components and platforms could not be set up:
Jan 04 22:09:18 ha-ubuntu hass[7408]: * [sun](https://home-assistant.io/components/sun/)
Jan 04 22:09:18 ha-ubuntu hass[7408]: Please check your config, service=create, service_call_id=139838079863384-1>
Jan 04 22:09:18 ha-ubuntu hass[7408]: Please check your config, service=create, service_call_id=139838079863384-2>
Jan 04 22:09:18 ha-ubuntu hass[7408]: * [automation.sun](https://home-assistant.io/components/automation.sun/)
Jan 04 22:09:18 ha-ubuntu hass[7408]: Please check your config, service=create, service_call_id=139838079863384-3>
Jan 04 22:09:18 ha-ubuntu hass[7408]: 17-01-04 22:09:18 INFO (MainThread) [homeassistant.components.automation] Initialized trigger Berto Left Work
Jan 04 22:09:18 ha-ubuntu hass[7408]: 17-01-04 22:09:18 INFO (MainThread) [homeassistant.components.automation] Initialized trigger Sleeping
Jan 04 22:09:18 ha-ubuntu hass[7408]: 17-01-04 22:09:18 INFO (MainThread) [homeassistant.components.automation] Initialized trigger Berto Wakeup
Jan 04 22:09:18 ha-ubuntu hass[7408]: 17-01-04 22:09:18 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_executed[L]: service_call_id=139838079863384-3>
Jan 04 22:09:18 ha-ubuntu hass[7408]: 17-01-04 22:09:18 INFO (MainThread) [homeassistant.bootstrap] Setting up sun
Jan 04 22:09:18 ha-ubuntu hass[7408]: 17-01-04 22:09:18 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: new_state=<state sun.sun=below_horizon; friendly_name=Sun, next_setting=2017-01-05T23:09:10+00:00, elevation=0, azimuth=0, next_rising=2017-01-05T13:36:25+00:00 @ 2017-01-04T22:09:18.568775-06:00>, old_state=None, entity_id=sun.sun>
Jan 04 22:09:18 ha-ubuntu hass[7408]: 17-01-04 22:09:18 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=sun>
Jan 04 22:09:18 ha-ubuntu hass[7408]: 17-01-04 22:09:18 INFO (MainThread) [homeassistant.components.automation] Initialized trigger Berto Leaving
Any ideas here?
