Hi everybody,
I have an problem with Automations,I tried some Automation on via UI but it is not triggered .I tetsted in with trigger it worked. Then ı tryid below link applicatin but it was not work.(I add my temrature sensor)
Please share the automation YAML. Make sure to format properly as a code block.
Thanks,
Im not at home now .Im not goig to be at home 4 hour later . When I arrive at home I will share it.
Manually triggering an automation bypasses the a actual trigger and just runs any conditions and actions.
Please post your trigger yaml, highlight it, then press the </> button to format it as code.
Or post a screenshot of the trigger using the UI editor
It also bypasses conditions
Thanks Guys ,
I resolve the problem .
But I copied some Automation code Automation.yaml but it is not working.Sample code is below.
automation:
alias: Turn on kitchen light when there is movement
platform: state
entity_id: sensor.motion_sensor
to: ‘on’
service: light.turn_on
entity_id: light.kitchen_light -
alias: Turn off kitchen light 10 minutes after last movement
platform: state
to: ‘off’
for:
minutes: 10
service: light.turn_off
Post it as a CODE block… hard to help with what you posted.
