Automations Keeps turning off
My Automation seems to now all of a sudden since the last core update to start to turn itself off on its own and I have to keep going back into Automations to turn it back on and no clue what’s causing it to have just started to do this.
It’s wired up to a switch on the stairs for the bulb to come on after sunset with the sensor!
alias: Downstairs Light
description: ""
triggers:
  - type: motion
    device_id: afd13551afdbfcab82eb77c57d10ed9e
    entity_id: 4e10ab35900c471b2d8fdcad6af3be7a
    domain: binary_sensor
    trigger: device
  - type: no_motion
    for:
      hours: 0
      minutes: 3
      seconds: 0
    trigger: device
conditions: []
actions:
  - choose:
      - conditions:
          - condition: trigger
            id:
              - light-on
          - condition: sun
            before: sunrise
            after: sunset
        sequence:
          - data: {}
            action: light.turn_on
              entity_id: light.down_stairs_light
      - conditions:
            id:
              - light-off
        sequence:
          - data: {}
            action: light.turn_off
mode: single
The Sensor is a Zigbee one from Aqara and the bulb is a AISIRER Alexa Smart Bulb WiFi Light Bulbs E27 Screw, 2 Pack, 10W 1000LM, App or Voice Control, 90W Dimmable White and RGBCW Colour Changing Light Bulb, Works with Alexa, Google Home, No Hub Required
If the automation is being disabled you need to look at the logbook for the automation. There doesn’t seem to be anything in the automation’s config that would cause that.
What do I need to be looking out for as I no clue what the updates have done, and not well up on the log book? thanks!
I had a look and seems to have a lot of errors in there from the core! not I did make a backup and restore my setup!
You haven’t perhaps assigned an area to the automation? I did that thinking it would let me easily see automations impacting a specific room. But I also had a generic turn off for the room thinking it would turn off all the lights. Duh! It also turned off the automations in the area.
Yes they are already set to an area. So are you saying something can be making this Automation turn off everything in the room.
If an automation is assigned an area and some script or automation issues a generic “turn off” with that room as a target (which you might do if you had both switches and dimmers in the room and simply wanted to turn off all the lights in the room at once) it will also turn off the automation. Makes sense but surprising nonetheless. My conclusion is that it is seldom a good idea to assign an area to an automation.
