Automations not running when triggered
Hi all
I am truly stumped. I’m setting up an button like I’ve done before many times but the automations will just not run. I’ve done the most simple one of toggling a light and I can see it’s being triggered (both in logbook and by the “Triggered” bar that flashes up in the UI, but nothing happens. Traces don’t show anything (assuming since no actions were run). I’ve checked my other automations and they run fine but still won’t when adding the button as another trigger (although still showing that it is triggered). I’ve tried with 2 different buttons now with same behaviour and also added the working button to the test automation but it also won’t run the action. I checked the action by clicking “run” and it works fine.
What have I stuffed up? Below is my code.
alias: test Automation
description: ""
triggers:
  - trigger: state
    entity_id:
      - sensor.button_main_bedroom_carrie_action
    to: single
conditions: []
actions:
  - action: light.toggle
      entity_id: light.group_lights_dining_room
    data: {}
mode: single
Just to add, I also tested via a time trigger and getting the same behaviour. It’s like the “then do” part is not being progressed.
The test with clicking run makes sure that the action part is correct, so your issue is in the trigger part.
Is the name correct?
Is the state value correct?
Use the developer tools to check
Yes, name is correct and States in the developer tools will show the “single” state when pressed.
But the automation is showing as triggered as in pic below. Surely that would mean that the trigger is fine and that the automation has been triggered now?
If it has, then there should be a trace.
Try with a different action.
Like notification or something that is local on the HA machine
action: notify.persistent_notification
  message: test
Should give you:
Tried that and still not getting anything through. Also still showing “no traces found”
Ok, found the problem. There was a typo in configuration.yaml that I missed and didn’t follow the process as I was in a rush when making the change, so didn’t check configuration. Only found out when deciding to do a full restart and the system didn’t come up properly. Fixed and all working now. Strange behaviour though. I would have thought I’d get an error or the whole system would fall over. But just for actions on new automations to not work is weird. Anyway, just glad it’s working again and thanks for the helping suggestions.
