Automations not showing in GUI
Hi all, my first post so please go easy! I’ve only been trying HA out for a couple of weeks.
I have an issue where I cannot add any automations apart from one I added a few days ago (auto backup config each night).
When I add an automation in the GUI and save it, it does not show in the list. However, it does drop in to my automations.yaml file.
If I drop both automations from the YAML file, the nightly automation still shows in the GUI. If I swap them around so my new automation is at the top of the file, still only the nightly automation shows.
What is going on here?
configuration.yaml
# Loads default set of integrations. Do not remove.
default_config:
# Load frontend themes from the themes folder
frontend:
  themes: !include_dir_merge_named themes
automation: !include automations.yaml
script: !include scripts.yaml
scene: !include scenes.yaml
http:
  use_x_forwarded_for: true
  trusted_proxies:
    - 192.168.27.0/24
    - 172.30.33.0/24
template:
  - sensor:
      - name: "custom_octopus_energy_current_rate_formatted"
        unit_of_measurement: "p"
        state: >-
          {{ (states('sensor.octopus_energy_electricity_19l3667208_1411993310004_current_rate') | float * 100) | round(1) }}
  - sensor:
      - name: "custom_octopus_energy_next_rate_formatted"
        state: >-
          {{ (states('sensor.octopus_energy_electricity_19l3667208_1411993310004_next_rate') | float * 100) | round(1) }}
  - sensor:
      - name: "test_value"
        unit_of_measurement: "gal"
        state: >
automations.yaml
- id: "1728031921029"
  alias: Nightly Backups to NAS
  description: ""
  triggers:
    - trigger: time
      at: 01:00:00
  conditions: []
  actions:
    - action: hassio.backup_full
      metadata: {}
        compressed: true
- id: "1728501725184"
  alias: "Notify: Motion detected in the Study"
  description: ""
  triggers:
    - type: occupied
      device_id: e8e4306daa48fe581faae9f60f510520
      entity_id: 85d343fa2e13ad9633ad3983874ed3b8
      domain: binary_sensor
      trigger: device
  conditions: []
  actions:
    - action: notify.mobile_app_maffoos_iphone
        title: Study motion
        message: Someone is in the study!
Hi, welcome to the forum!
Have you refreshed your browser / cleared the cache / tried with another browser?
Did you read this: Splitting up the configuration - Home AssistantExample: Combine !include_dir_merge_list with automations.yaml
Are you sure that this is correct?
Could your automation be disabled - and due to some active filters in “Automations” list you cannot see it?
ALso, check this:
Thanks all!
I did all sorts to get this working. In the end I just rebooted and it all started working normally.
I have no idea what happened but thanks a lot for the replies!
