About a few updates ago after they included the new if then in automations my automations are not triggering like they use to. it is hit or miss whether they work or not. I monitor my z-wave motions and they go safe as normal but the automation does not trigger. it worked flawlessly before the update. I even went back in and created new automations same result. I will walk by the light will not turn on then a few minutes later I walk by and they turn on. it is not something to do with my setup as everything was working before. I have tried all of the normal troubleshooting techniques. I have been reading on this forum too that others are having some issues with automations. I also noticed that time of day sensors do not work correctly anymore. I have to restart HA for it to correct but then after the day changes it will not properly update.
has anyone else experienced this?
