A lot of my automations, most of them regarding my ZigBee light switches, randomly stop working (The automations are not running, and the lights don’t turn on/off. I have figured out that if I go into the automation, and change the event for the light switch from button pressed to button released, and then back to button pressed to then be able to save the automation, it starts working again. This happens multiple times everyday.
So basically, I have to make a change to the automation and then save it, and it will start working again.
What is the problem, and how can this be fixed?
Check your logs.
Post an example of an automation that does this.
