This is what I am trying to accomplish:
After the windows is opened and then closed the thermostat should be set to the status (temperature/on/off) state it was from the scheduled automation2.
Automation1:
The bathroom windows sensor (on/off-window closed) triggers the floor heating thermostat to “off” when windows opened. When windows closed the thermostat is turned on.
Automation2.
Day scheduling of the floor thermostat like on 06:00 in the morning (23C), 12:00 off, 17:00 on and 23:59 off (the off state will in wintertime be set to X degrees C.)
Here is the challenge:
I take a shower at 11:40 and the thermostat is on heating with temperature 23C.
After showering I open the window at 12:10 and the thermostat is set to “off”.
Automation2 has from 12:00 set the thermostat to “off”.
I close the window at 12:30 and Atumation1 will then set the thermostat to “on”, - which it should not. It should respect (set the status on/off/temperature) settings from Automation2.
Can I have some Automation variable/trigger variable so the two automations can check the other automation variable status?
Automation1:
alias: 'Thermostat Floor ON/OFF for Window Sensor: Bathroom '
description: When Windows opens Thermostat turns OFF, when closes Thermostat turn on again
- platform: state
entity_id:
- binary_sensor.window_sensor1_access_control
for:
hours: 0
minutes: 0
seconds: 15
to: 'on'
condition:
- condition: state
entity_id: climate.floor_thermostat1
state: heat
- service: climate.turn_off
data: {}
device_id: 7719252a76ec7b7f5219b716b5d429f1
- wait_for_trigger:
- platform: state
entity_id:
to: 'off'
- service: climate.turn_on
data: {}
mode: restart
Automation2:
alias: 'Thermostat Floor Schedules: Bathroom '
description: Set bathroom floor thermostat temperature for night and day
- platform: time
at: '08:00:00'
- platform: time
at: '12:00:00'
- platform: time
at: '17:00:00'
- platform: time
at: '23:59:00'
condition: ()
- wait_template: '{{ is_state(''binary_sensor.window_sensor1_access_control'', ''off'') }}'
- choose:
- conditions:
- condition: trigger
sequence:
data: {}
- delay:
hours: 0
minutes: 0
seconds: 15
milliseconds: 0
- service: climate.set_temperature
temperature: 23
- conditions:
sequence:
data: {}
default: []
mode: restart
