Updated my home assistant now it looks like a lot of my automations are no longer working. It has been over a year since the last time I updated and even longer since I made these automations and I don’t remember anything.
Log (i think)
2017-11-17 14:00:30 ERROR (MainThread) [homeassistant.config] Invalid config for [automation]: [state] is an invalid option for [automation]. Check: automation->trigger->0->state. (See /home/homeassistant/.homeassistant/configuration.yaml, line 104). Please check the docs at https://home-assistant.io/components/automation/
2017-11-17 14:00:30 ERROR (MainThread) [homeassistant.config] Invalid config for [automation]: [after] is an invalid option for [automation]. Check: automation->trigger->0->after. (See /home/homeassistant/.homeassistant/configuration.yaml, line 104). Please check the docs at https://home-assistant.io/components/automation/
2017-11-17 14:00:31 ERROR (MainThread) [homeassistant.setup] Unable to setup dependencies of logbook. Setup failed for dependencies: recorder
2017-11-17 14:00:31 ERROR (MainThread) [homeassistant.setup] Setup failed for logbook: Could not setup all dependencies.
alias: “Turn on outlet 2 when it is nighttime”
platform: time
after: ‘21:00’
service: homeassistant.turn_on
entity_id: switch.outlet_2
alias: “Turn off outlet 2 when it is daytime”
platform: time
after: ‘09:00’
service: homeassistant.turn_off
Bedroom 3 Automations
Security System Automations
alias: “Security System”
platform: state
entity_id: sensor.vision_zp3111_multisensor_4in1_alarm_level_3_1
state: ‘255’
platform: state
entity_id: binary_sensor.ecolink_pir_motion_sensor_sensor_4_0
state: ‘on’
service: notify.my_pushbullet
message: “someone is in the house”
target: “device/Galaxy S5”
alias: ‘Arm Security When Away’
platform: state
entity_id: input_boolean.family_home
to: ‘off’
entity_id: automation.security_system
alias: ‘Disarm Security When Home’
platform: state
to: ‘on’
Some syntax has been changed, you need to go through your automations and change the triggers slightly.
Where you have a time trigger change the word ‘after’ to ‘at’.
Where you have state triggers change the second ‘state’ (not the declaration that it is a state trigger, the bit where your saying what state it should be in to trigger) to ‘to’.
I wasn’t able to find what you were talking about. so i removed everything and have just one automation. I still cant get this one automation working. Any help is appreciated
####Automation
automation:
platform: time
after: ‘21:00’
platform: time
after: ‘09:00’
2017-11-22 12:38:29 ERROR (MainThread) [homeassistant.loader] Unable to find component input_slider
2017-11-22 12:38:29 ERROR (MainThread) [homeassistant.setup] Setup failed for input_slider: Component not found.
2017-11-22 12:38:30 ERROR (MainThread) [homeassistant.components] Testing configuration at /home/homeassistant/.homeassistant
2017-11-22 12:38:29 INFO (MainThread) [homeassistant.setup] Setting up mqtt
2017-11-22 12:38:29 INFO (MainThread) [homeassistant.setup] Setting up http
2017-11-22 12:38:29 INFO (MainThread) [homeassistant.setup] Setting up recorder
2017-11-22 12:38:29 INFO (MainThread) [homeassistant.setup] Setup of domain mqtt took 0.0 seconds.
2017-11-22 12:38:29 INFO (MainThread) [homeassistant.setup] Setup of domain http took 0.0 seconds.
2017-11-22 12:38:29 INFO (MainThread) [homeassistant.setup] Setup of domain recorder took 0.0 seconds.
2017-11-22 12:38:29 INFO (MainThread) [homeassistant.setup] Setting up api
2017-11-22 12:38:29 INFO (MainThread) [homeassistant.setup] Setting up websocket_api
2017-11-22 12:38:29 INFO (MainThread) [homeassistant.setup] Setting up history
2017-11-22 12:38:29 INFO (MainThread) [homeassistant.setup] Setup of domain api took 0.0 seconds.
2017-11-22 12:38:29 INFO (MainThread) [homeassistant.setup] Setup of domain websocket_api took 0.0 seconds.
2017-11-22 12:38:29 INFO (MainThread) [homeassistant.setup] Setup of domain history took 0.0 seconds.
2017-11-22 12:38:29 INFO (MainThread) [homeassistant.setup] Setting up frontend
2017-11-22 12:38:29 INFO (MainThread) [homeassistant.setup] Setup of domain frontend took 0.0 seconds.
2017-11-22 12:38:29 INFO (MainThread) [homeassistant.setup] Setting up zwave
2017-11-22 12:38:29 INFO (MainThread) [homeassistant.setup] Setting up group
2017-11-22 12:38:29 INFO (MainThread) [homeassistant.setup] Setting up notify
2017-11-22 12:38:29 INFO (MainThread) [homeassistant.setup] Setting up discovery
2017-11-22 12:38:29 INFO (MainThread) [homeassistant.setup] Setting up scene
2017-11-22 12:38:29 INFO (MainThread) [homeassistant.setup] Setting up emulated_hue
2017-11-22 12:38:29 INFO (MainThread) [homeassistant.setup] Setting up updater
2017-11-22 12:38:29 INFO (MainThread) [homeassistant.setup] Setting up google
2017-11-22 12:38:29 INFO (MainThread) [homeassistant.setup] Setting up sun
2017-11-22 12:38:29 INFO (MainThread) [homeassistant.setup] Setting up input_boolean
2017-11-22 12:38:29 INFO (MainThread) [homeassistant.setup] Setting up zone
2017-11-22 12:38:29 INFO (MainThread) [homeassistant.setup] Setting up sensor
2017-11-22 12:38:29 INFO (MainThread) [homeassistant.setup] Setup of domain zwave took 0.4 seconds.
2017-11-22 12:38:29 INFO (MainThread) [homeassistant.setup] Setup of domain group took 0.4 seconds.
2017-11-22 12:38:29 INFO (MainThread) [homeassistant.setup] Setup of domain notify took 0.3 seconds.
2017-11-22 12:38:29 INFO (MainThread) [homeassistant.setup] Setup of domain discovery took 0.3 seconds.
2017-11-22 12:38:29 INFO (MainThread) [homeassistant.setup] Setup of domain scene took 0.3 seconds.
2017-11-22 12:38:29 INFO (MainThread) [homeassistant.setup] Setup of domain emulated_hue took 0.2 seconds.
2017-11-22 12:38:29 INFO (MainThread) [homeassistant.setup] Setup of domain updater took 0.2 seconds.
2017-11-22 12:38:29 INFO (MainThread) [homeassistant.setup] Setup of domain google took 0.2 seconds.
2017-11-22 12:38:29 INFO (MainThread) [homeassistant.setup] Setup of domain sun took 0.2 seconds.
2017-11-22 12:38:29 INFO (MainThread) [homeassistant.setup] Setup of domain input_boolean took 0.2 seconds.
2017-11-22 12:38:29 INFO (MainThread) [homeassistant.setup] Setup of domain zone took 0.2 seconds.
2017-11-22 12:38:29 INFO (MainThread) [homeassistant.setup] Setup of domain sensor took 0.2 seconds.
2017-11-22 12:38:29 INFO (MainThread) [homeassistant.setup] Setting up tts
2017-11-22 12:38:29 INFO (MainThread) [homeassistant.setup] Setting up conversation
2017-11-22 12:38:29 INFO (MainThread) [homeassistant.setup] Setting up logbook
2017-11-22 12:38:29 INFO (MainThread) [homeassistant.setup] Setting up switch
2017-11-22 12:38:29 INFO (MainThread) [homeassistant.setup] Setting up automation
2017-11-22 12:38:29 INFO (MainThread) [homeassistant.setup] Setting up script
2017-11-22 12:38:29 INFO (MainThread) [homeassistant.setup] Setup of domain tts took 0.0 seconds.
2017-11-22 12:38:29 INFO (MainThread) [homeassistant.setup] Setup of domain conversation took 0.0 seconds.
2017-11-22 12:38:29 INFO (MainThread) [homeassistant.setup] Setting up device_tracker
2017-11-22 12:38:29 INFO (MainThread) [homeassistant.setup] Setup of domain logbook took 0.0 seconds.
2017-11-22 12:38:29 INFO (MainThread) [homeassistant.setup] Setup of domain switch took 0.0 seconds.
2017-11-22 12:38:29 INFO (MainThread) [homeassistant.setup] Setup of domain automation took 0.0 seconds.
2017-11-22 12:38:29 INFO (MainThread) [homeassistant.setup] Setup of domain script took 0.0 seconds.
2017-11-22 12:38:29 INFO (MainThread) [homeassistant.setup] Setup of domain device_tracker took 0.0 seconds.
2017-11-22 12:38:29 INFO (MainThread) [homeassistant.setup] Setting up proximity
2017-11-22 12:38:29 INFO (MainThread) [homeassistant.setup] Setup of domain proximity took 0.0 seconds.
Failed config
General Errors:
- Component not found: input_slider
- Setup failed for input_slider: Component not found.
Thanks that is good to know I will work on that soon. Right now i cant even get a simple automation working right. Just thought i would start with the simple stuff first and as things start working again tackle the other stuff.
platform: time
at: ‘21:00:00’
platform: time
at: ‘09:00:00’
platform: state
state: ‘255’
platform: state
state: ‘on’
platform: state
to: ‘off’
platform: state
to: ‘on’
2017-11-22 14:32:38 ERROR (MainThread) [homeassistant.config] Invalid config for [automation]: [state] is an invalid option for [automation]. Check: automation->trigger->0->state. (See /home/homeassistant/.homeassistant/configuration.yaml, line 104). Please check the docs at https://home-assistant.io/components/automation/
2017-11-22 14:32:38 ERROR (MainThread) [homeassistant.components] Testing configuration at /home/homeassistant/.homeassistant
2017-11-22 14:32:37 INFO (MainThread) [homeassistant.setup] Setting up mqtt
2017-11-22 14:32:37 INFO (MainThread) [homeassistant.setup] Setup of domain mqtt took 0.0 seconds.
2017-11-22 14:32:37 INFO (MainThread) [homeassistant.setup] Setting up http
2017-11-22 14:32:37 INFO (MainThread) [homeassistant.setup] Setting up recorder
2017-11-22 14:32:37 INFO (MainThread) [homeassistant.setup] Setup of domain http took 0.0 seconds.
2017-11-22 14:32:37 INFO (MainThread) [homeassistant.setup] Setup of domain recorder took 0.0 seconds.
2017-11-22 14:32:37 INFO (MainThread) [homeassistant.setup] Setting up api
2017-11-22 14:32:37 INFO (MainThread) [homeassistant.setup] Setting up websocket_api
2017-11-22 14:32:37 INFO (MainThread) [homeassistant.setup] Setting up history
2017-11-22 14:32:37 INFO (MainThread) [homeassistant.setup] Setup of domain api took 0.0 seconds.
2017-11-22 14:32:37 INFO (MainThread) [homeassistant.setup] Setup of domain websocket_api took 0.0 seconds.
2017-11-22 14:32:37 INFO (MainThread) [homeassistant.setup] Setup of domain history took 0.0 seconds.
2017-11-22 14:32:37 INFO (MainThread) [homeassistant.setup] Setting up frontend
2017-11-22 14:32:37 INFO (MainThread) [homeassistant.setup] Setup of domain frontend took 0.0 seconds.
2017-11-22 14:32:37 INFO (MainThread) [homeassistant.setup] Setting up input_boolean
2017-11-22 14:32:37 INFO (MainThread) [homeassistant.setup] Setting up scene
2017-11-22 14:32:38 INFO (MainThread) [homeassistant.setup] Setting up notify
2017-11-22 14:32:38 INFO (MainThread) [homeassistant.setup] Setting up input_number
2017-11-22 14:32:38 INFO (MainThread) [homeassistant.setup] Setting up zwave
2017-11-22 14:32:38 INFO (MainThread) [homeassistant.setup] Setting up google
2017-11-22 14:32:38 INFO (MainThread) [homeassistant.setup] Setting up sensor
2017-11-22 14:32:38 INFO (MainThread) [homeassistant.setup] Setting up zone
2017-11-22 14:32:38 INFO (MainThread) [homeassistant.setup] Setting up updater
2017-11-22 14:32:38 INFO (MainThread) [homeassistant.setup] Setting up discovery
2017-11-22 14:32:38 INFO (MainThread) [homeassistant.setup] Setting up sun
2017-11-22 14:32:38 INFO (MainThread) [homeassistant.setup] Setting up group
2017-11-22 14:32:38 INFO (MainThread) [homeassistant.setup] Setting up emulated_hue
2017-11-22 14:32:38 INFO (MainThread) [homeassistant.setup] Setup of domain input_boolean took 0.6 seconds.
2017-11-22 14:32:38 INFO (MainThread) [homeassistant.setup] Setup of domain scene took 0.4 seconds.
2017-11-22 14:32:38 INFO (MainThread) [homeassistant.setup] Setup of domain notify took 0.4 seconds.
2017-11-22 14:32:38 INFO (MainThread) [homeassistant.setup] Setup of domain input_number took 0.4 seconds.
2017-11-22 14:32:38 INFO (MainThread) [homeassistant.setup] Setup of domain zwave took 0.4 seconds.
2017-11-22 14:32:38 INFO (MainThread) [homeassistant.setup] Setup of domain google took 0.3 seconds.
2017-11-22 14:32:38 INFO (MainThread) [homeassistant.setup] Setup of domain sensor took 0.3 seconds.
2017-11-22 14:32:38 INFO (MainThread) [homeassistant.setup] Setup of domain zone took 0.3 seconds.
2017-11-22 14:32:38 INFO (MainThread) [homeassistant.setup] Setup of domain updater took 0.3 seconds.
2017-11-22 14:32:38 INFO (MainThread) [homeassistant.setup] Setup of domain discovery took 0.3 seconds.
2017-11-22 14:32:38 INFO (MainThread) [homeassistant.setup] Setup of domain sun took 0.3 seconds.
2017-11-22 14:32:38 INFO (MainThread) [homeassistant.setup] Setup of domain group took 0.1 seconds.
2017-11-22 14:32:38 INFO (MainThread) [homeassistant.setup] Setup of domain emulated_hue took 0.1 seconds.
2017-11-22 14:32:38 INFO (MainThread) [homeassistant.setup] Setting up conversation
2017-11-22 14:32:38 INFO (MainThread) [homeassistant.setup] Setting up logbook
2017-11-22 14:32:38 INFO (MainThread) [homeassistant.setup] Setting up tts
2017-11-22 14:32:38 INFO (MainThread) [homeassistant.setup] Setup of domain conversation took 0.0 seconds.
2017-11-22 14:32:38 INFO (MainThread) [homeassistant.setup] Setup of domain logbook took 0.0 seconds.
2017-11-22 14:32:38 INFO (MainThread) [homeassistant.setup] Setting up script
2017-11-22 14:32:38 INFO (MainThread) [homeassistant.setup] Setting up switch
2017-11-22 14:32:38 INFO (MainThread) [homeassistant.setup] Setting up device_tracker
2017-11-22 14:32:38 INFO (MainThread) [homeassistant.setup] Setting up automation
2017-11-22 14:32:38 INFO (MainThread) [homeassistant.setup] Setup of domain tts took 0.0 seconds.
2017-11-22 14:32:38 INFO (MainThread) [homeassistant.setup] Setup of domain script took 0.0 seconds.
2017-11-22 14:32:38 INFO (MainThread) [homeassistant.setup] Setup of domain switch took 0.0 seconds.
2017-11-22 14:32:38 INFO (MainThread) [homeassistant.setup] Setup of domain device_tracker took 0.0 seconds.
2017-11-22 14:32:38 INFO (MainThread) [homeassistant.setup] Setup of domain automation took 0.0 seconds.
2017-11-22 14:32:38 INFO (MainThread) [homeassistant.setup] Setting up proximity
2017-11-22 14:32:38 INFO (MainThread) [homeassistant.setup] Setup of domain proximity took 0.0 seconds.
Failed config
automation:
- action: [source /home/homeassistant/.homeassistant/automation.yaml:22]
entity_id: script.kitchen_timed_light
alias: Turn on kitchen lights when there is movement
condition: [source /home/homeassistant/.homeassistant/automation.yaml:15]
condition: or
conditions: [source /home/homeassistant/.homeassistant/automation.yaml:17]
- condition: template
value_template: {{ states.sun.sun.attributes.elevation < 15 }}
value_template: {{ states.sensor.vision_zp3111_multisensor_4in1_luminance_3_3.state < 45 }}
trigger: [source /home/homeassistant/.homeassistant/automation.yaml:6]
- platform: state
state: 255
- platform: state
entity_id: switch.ge_12722_onoff_relay_switch_switch_2_0
state: on
- platform: state
entity_id: input_number.kitchen_timer
- action: [source /home/homeassistant/.homeassistant/automation.yaml:32]
entity_id: scene.nighttime
alias: nighttime timer on
trigger: [source /home/homeassistant/.homeassistant/automation.yaml:27]
platform: time
at: 22:00:00
- action: [source /home/homeassistant/.homeassistant/automation.yaml:43]
entity_id: scene.daytime
alias: daytime timer on
trigger: [source /home/homeassistant/.homeassistant/automation.yaml:38]
platform: time
at: 07:30:00
- action: [source /home/homeassistant/.homeassistant/automation.yaml:68]
entity_id: script.bathroom_timed_light
alias: Turn on bath lights when there is movement
condition: [source /home/homeassistant/.homeassistant/automation.yaml:61]
condition: or
conditions: [source /home/homeassistant/.homeassistant/automation.yaml:63]
trigger: [source /home/homeassistant/.homeassistant/automation.yaml:52]
- platform: state
state: on
- platform: state
entity_id: switch.ge_12722_onoff_relay_switch_switch_5_0
state: on
- platform: state
entity_id: input_number.bathroom_shower
- action: [source /home/homeassistant/.homeassistant/automation.yaml:76]
- delay: 00:01:00
- entity_id: switch.outlet_4
alias: turn on bathroom fan for bath time
trigger: [source /home/homeassistant/.homeassistant/automation.yaml:73]
- platform: state
- action: [source /home/homeassistant/.homeassistant/automation.yaml:85]
- delay: 01:00:00
alias: turn off bathroom fan for bath time
trigger: [source /home/homeassistant/.homeassistant/automation.yaml:82]
- platform: state
- action: [source /home/homeassistant/.homeassistant/automation.yaml:110]
entity_id: script.bedroom_1_timed_light
alias: Turn on bedroom 1 lights when there is movement
condition: [source /home/homeassistant/.homeassistant/automation.yaml:103]
condition: or
conditions: [source /home/homeassistant/.homeassistant/automation.yaml:105]
trigger: [source /home/homeassistant/.homeassistant/automation.yaml:94]
- platform: state
entity_id: sensor.gr_unknown_type0500_id0003_burglar_8_10
state: 8
- platform: state
entity_id: light.ge_12730_fan_control_switch_level_9_0
state: on
- platform: state
entity_id: input_number.bedroom_1_timer
- action: [source /home/homeassistant/.homeassistant/automation.yaml:119]
- delay: 00:04:00
- entity_id: switch.ge_12722_onoff_relay_switch_switch_11_0
alias: Turn on Bedroom 1 Closet Light Timer
trigger: [source /home/homeassistant/.homeassistant/automation.yaml:115]
- platform: state
state: on
- action: [source /home/homeassistant/.homeassistant/automation.yaml:128]
entity_id: switch.outlet_1
alias: Turn on outlet 1 when it is nighttime
trigger: [source /home/homeassistant/.homeassistant/automation.yaml:125]
- platform: time
at: 20:00:00
- action: [source /home/homeassistant/.homeassistant/automation.yaml:136]
alias: Turn off outlet 1 when it is daytime
trigger: [source /home/homeassistant/.homeassistant/automation.yaml:133]
- platform: time
at: 09:00:00
- action: [source /home/homeassistant/.homeassistant/automation.yaml:146]
entity_id: scene.bedroom_1_nighttime
alias: Bedroom 1 Nighttime Timer On
trigger: [source /home/homeassistant/.homeassistant/automation.yaml:141]
platform: time
at: 20:00:00
- action: [source /home/homeassistant/.homeassistant/automation.yaml:157]
entity_id: scene.bedroom_1_daytime
alias: Bedroom 1 Daytime Timer On
trigger: [source /home/homeassistant/.homeassistant/automation.yaml:152]
platform: time
at: 08:30:00
- action: [source /home/homeassistant/.homeassistant/automation.yaml:169]
alias: Turn on outlet 2 when it is nighttime
trigger: [source /home/homeassistant/.homeassistant/automation.yaml:166]
- platform: time
at: 21:00:00
- action: [source /home/homeassistant/.homeassistant/automation.yaml:177]
alias: Turn off outlet 2 when it is daytime
trigger: [source /home/homeassistant/.homeassistant/automation.yaml:174]
- platform: time
at: 09:00:00
- action: [source /home/homeassistant/.homeassistant/automation.yaml:195]
data: [source /home/homeassistant/.homeassistant/automation.yaml:197]
message: someone is in the house
target: device/Galaxy S5
alias: Security System
trigger: [source /home/homeassistant/.homeassistant/automation.yaml:188]
- platform: state
state: 255
- platform: state
state: on
- action: [source /home/homeassistant/.homeassistant/automation.yaml:207]
alias: Arm Security When Away
trigger: [source /home/homeassistant/.homeassistant/automation.yaml:202]
platform: state
to: off
- action: [source /home/homeassistant/.homeassistant/automation.yaml:217]
alias: Disarm Security When Home
trigger: [source /home/homeassistant/.homeassistant/automation.yaml:212]
platform: state
to: on
- action: [source /home/homeassistant/.homeassistant/automation.yaml:236]
- entity_id: input_boolean.family_home
alias: Family Away
condition: [source /home/homeassistant/.homeassistant/automation.yaml:222]
condition: state
state: on
trigger: [source /home/homeassistant/.homeassistant/automation.yaml:226]
- platform: state
entity_id: device_tracker.mike_nmap
state: away
- platform: state
entity_id: device_tracker.rhina_nmap
state: away
- platform: state
entity_id: device_tracker.josh_nmap
state: away
- action: [source /home/homeassistant/.homeassistant/automation.yaml:255]
alias: Family Home
condition: [source /home/homeassistant/.homeassistant/automation.yaml:241]
condition: state
state: off
trigger: [source /home/homeassistant/.homeassistant/automation.yaml:245]
- platform: state
state: home
- platform: state
state: home
- platform: state
state: home
Successful config (partial)
automation:
- action: ?
- entity_id: ?
- scene.nighttime
hide_entity: False
trigger: ?
- platform: time
at: 22:00:00
- action: ?
- entity_id: ?
- scene.daytime
hide_entity: False
trigger: ?
- platform: time
at: 07:30:00
- action: ?
- delay: 0:01:00
- entity_id: ?
- switch.outlet_4
hide_entity: False
trigger: ?
- platform: state
entity_id: ?
- input_number.bathroom_shower
- action: ?
- delay: 1:00:00
- entity_id: ?
- switch.outlet_4
hide_entity: False
trigger: ?
- platform: state
entity_id: ?
- action: ?
- entity_id: ?
- switch.outlet_1
hide_entity: False
trigger: ?
- platform: time
at: 20:00:00
- action: ?
- entity_id: ?
- switch.outlet_1
hide_entity: False
trigger: ?
- platform: time
at: 09:00:00
- action: ?
- entity_id: ?
- scene.bedroom_1_nighttime
hide_entity: False
trigger: ?
- platform: time
at: 20:00:00
- action: ?
- entity_id: ?
- scene.bedroom_1_daytime
hide_entity: False
trigger: ?
- platform: time
at: 08:30:00
- action: ?
- entity_id: ?
- switch.outlet_2
hide_entity: False
trigger: ?
- platform: time
at: 21:00:00
- action: ?
- entity_id: ?
- switch.outlet_2
hide_entity: False
trigger: ?
- platform: time
at: 09:00:00
- action: ?
- entity_id: ?
- automation.security_system
hide_entity: False
trigger: ?
- platform: state
entity_id: ?
- input_boolean.family_home
to: off
- action: ?
- entity_id: ?
hide_entity: False
trigger: ?
- platform: state
entity_id: ?
to: on
