Automations triggering randomly
Good Day,
I want to automate a switch such that it switches off then on a minute later, I want this to happen every thirty seconds, I have this in my automation.yaml
  - alias: 'EnergyMeter_on'
     platform: time
     minutes: '/06'
     - service: switch.turn_on
       entity_id: switch.EnergyMeter
  - alias: 'EnergyMeter_off'
     platform: time
     minutes: '/05'
     - service: switch.turn_off
  - alias: 'EnergyMeter_on2'
     platform: time
     minutes: '/35'
  - alias: 'EnergyMeter_off2'
     platform: time
     minutes: '/34'
this automation triggers the switch in its own time, and it triggers quite a lot as you can see below, what am I doing wrong?
Logbook
History
Configuration
Log out
Developer tools
Logbook
Showing entries for
β€Ž10β€Ž:β€Ž09β€Ž β€ŽPM
Samsung LED50 (UA50HU7000) turned on
EnergyMeter turned on
Tsakibed turned on
Chrome_Caz1000 turned off
TsakiBackup turned on
β€Ž10β€Ž:β€Ž08β€Ž β€ŽPM
Home Assistant started
Weather Symbol changed to 1
EnergyMeter turned off
Garage turned off
Tsakibed turned off
β€Ž10β€Ž:β€Ž07β€Ž β€ŽPM
Home Assistant stopped
β€Ž10β€Ž:β€Ž06β€Ž β€ŽPM
EnergyMeter_on has been triggered
β€Ž10β€Ž:β€Ž05β€Ž β€ŽPM
EnergyMeter_off has been triggered
β€Ž10β€Ž:β€Ž03β€Ž β€ŽPM
Tsakibed turned on
β€Ž10β€Ž:β€Ž01β€Ž β€ŽPM
β€Ž10β€Ž:β€Ž00β€Ž β€ŽPM
EnergyMeter_on2 has been triggered
EnergyMeter_off2 has been triggered
EnergyMeter_off turned on
EnergyMeter_on turned on
tsakibed_off2 turned on
tsakibed_on2 turned on
tsakibed_off turned on
EnergyMeter_on2 turned on
tsakibed_on turned on
EnergyMeter_off2 turned on
After removing everything in automations.yaml and restarting at 10:07 pm, the switches behave normally.
Please assist, because it definitely has to do with my automation file.
I think your problem is that what you want to do doesn’t fit the laws of physics, unless you’re secretly Dr Who?
I’d suggest two automations.
One turns it on if it’s been off for a set period of time, the other turns it off if it’s been on for a set period of time.
alias: energy on
  platform: state
  entity_id: switch.energymeter
  state: 'on'
  for:
    seconds: 30
  switch.energymeter
alias: energy off
  platform: state
  state: 'off'
  for:
    seconds: 30
  switch.energymeter
I thought the β€˜/xx’ meant it will trigger that action xx minutes into each hour, which is what I want, my automation is simply to switch off and immediately on again and I want to do this every thirty minutes.
thanks, I want it to be mostly on, but I want to toggle It off and on every thirty minutes, the reason being that it sometimes needs a reset, otherwise the meter behind it stops sending data.
Then pick your time intervals to suit what you want. Sounds like you want to use minutes: 30 for the first one.
Ok, let me try it without the β€˜/’
it works without the β€˜/’, thanks
Without / it’ll just trigger at that many minutes past the hour. If both are triggering at the same time you run the risk of them firing in the β€œwrong” order (on, then off).
I now have them firing as I want, thanks
