Is there a way of ensuring that automations stay on all the time, my automations shut down all at once at 4:07AM, and never came back up again, I suspect there was internet unavailability because everything else was also unavailable from that time.
Not sure why automation would switch off when there is not internet, maybe your system rebooted? You could set initial_state to make sure they are running.
I have this problem too occasionally. Usually my automations stay on after a restart, but occasionally a day starts and no automations are running, looks like they all got switched off somehow.
Surely initial_state: 'on' shouldn’t be necessary here? Unless default behaviour is all automations switch “off” after every restart?
Same here… when I start HA now my automations are all off, this was never the case before… started after a reboot… tried turning them on and they magically turn back off.
Sometimes, all automations turn off.
I noticed it today and can show these 2 logs that happened at the same time the automations turned off:
1st
## Log Details (WARNING)
Fri May 17 2019 13:45:50 GMT+0200 (Midden-Europese zomertijd)
Ended unfinished session (id=6 from 2019-05-17 11:43:42.360833)
2nd
Log Details (ERROR)
Fri May 17 2019 13:45:55 GMT+0200 (Midden-Europese zomertijd)
Error doing job: Task exception was never retrieved
File "/usr/local/lib/python3.7/site-packages/homeassistant/helpers/entity.py", line 215, in async_update_ha_state
"No entity id specified for entity {}".format(self.name))
homeassistant.exceptions.NoEntitySpecifiedError: No entity id specified for entity i5
