Automations with multiple independent conditions + actions
I’m trying to set up an automation that when i arm my alarm, it checks all my window sensors (mixture of device and binary sensors) and will then send a notification to my phone to say X window is open.
This is fairly straightforward for a single sensor, but i’m having some problems trying to incorporate multiple sensors with a condition and action. They have to be independent though as some windows may be closed and others open.
For action type i’ve tried “repeat”:
repeat:
  count: '1'
  sequence:
    - choose:
        - conditions:
            - type: is_open
              condition: device
              device_id: 20963e11fa1ce93c59e42a7e8d0f13e1
              entity_id: binary_sensor.openclose_24
              domain: binary_sensor
          sequence:
            - service: notify.mobile_app_g8341
                message: Bedroom window open
        - conditions:
            - condition: state
              entity_id: binary_sensor.office_window
              state: 'on'
          sequence:
                message: Bathroom window open
      default: []
But this only runs through the first condition.
I’ve also tried action type “choose” with multiple options:
choose:
  - conditions:
      - type: is_open
        condition: device
    sequence:
  - conditions:
      - condition: state
        state: 'on'
    sequence:
default: []
But that always picks the first option, it may go on to the second option if the first condition is false i haven’t tested that.
Any ideas? Is the automation i’m trying to create even possible? or should i stick to individual automations for each window sensor?
TIA.
You can make a group of your window/door entity and uses expand() as well as selectattr() function to only select the ones that are open.
Take a look at this-
  - service: notify.mobile_app_your_phone
      message: >
        {% set x = expand('binary_sensor.openclose_24', 'binary_sensor.office_window') | selectattr('state', 'eq', 'on') | map(attribute='name') | list %}
        Alert! The following {{'are' if x | count > 1 else 'is'}} open: {{ w | join(', ') }}
