It’d be neat if this would get fixed. I just got the ‘500’ error. After reconstructing several automations to add to my last backup it happened again.
Here’s the log:
2020-11-06 16:10:37 ERROR (SyncWorker_8) [homeassistant.util.yaml.loader] unacceptable character #x0000: special characters are not allowed
in "/config/automations.yaml", position 0
2020-11-06 16:10:37 ERROR (MainThread) [aiohttp.server] Error handling request
File "/usr/src/homeassistant/homeassistant/util/yaml/loader.py", line 61, in load_yaml
return yaml.load(conf_file, Loader=SafeLineLoader) or OrderedDict()
File "/usr/local/lib/python3.8/site-packages/yaml/__init__.py", line 112, in load
loader = Loader(stream)
File "/usr/local/lib/python3.8/site-packages/yaml/loader.py", line 34, in __init__
Reader.__init__(self, stream)
File "/usr/local/lib/python3.8/site-packages/yaml/reader.py", line 85, in __init__
self.determine_encoding()
File "/usr/local/lib/python3.8/site-packages/yaml/reader.py", line 135, in determine_encoding
self.update(1)
File "/usr/local/lib/python3.8/site-packages/yaml/reader.py", line 169, in update
self.check_printable(data)
File "/usr/local/lib/python3.8/site-packages/yaml/reader.py", line 143, in check_printable
raise ReaderError(self.name, position, ord(character),
yaml.reader.ReaderError: unacceptable character #x0000: special characters are not allowed
File "/usr/local/lib/python3.8/site-packages/aiohttp/web_protocol.py", line 418, in start
resp = await task
File "/usr/local/lib/python3.8/site-packages/aiohttp/web_app.py", line 458, in _handle
resp = await handler(request)
File "/usr/local/lib/python3.8/site-packages/aiohttp/web_middlewares.py", line 119, in impl
return await handler(request)
File "/usr/src/homeassistant/homeassistant/components/http/request_context.py", line 18, in request_context_middleware
File "/usr/src/homeassistant/homeassistant/components/http/ban.py", line 72, in ban_middleware
File "/usr/src/homeassistant/homeassistant/components/http/auth.py", line 127, in auth_middleware
File "/usr/src/homeassistant/homeassistant/components/http/view.py", line 129, in handle
result = await result
File "/usr/src/homeassistant/homeassistant/components/config/__init__.py", line 124, in get
current = await self.read_config(hass)
File "/usr/src/homeassistant/homeassistant/components/config/__init__.py", line 192, in read_config
current = await hass.async_add_executor_job(_read, hass.config.path(self.path))
File "/usr/local/lib/python3.8/concurrent/futures/thread.py", line 57, in run
File "/usr/src/homeassistant/homeassistant/components/config/__init__.py", line 252, in _read
return load_yaml(path)
File "/usr/src/homeassistant/homeassistant/util/yaml/loader.py", line 64, in load_yaml
raise HomeAssistantError(exc) from exc
homeassistant.exceptions.HomeAssistantError: unacceptable character #x0000: special characters are not allowed
2020-11-06 16:11:44 ERROR (SyncWorker_8) [homeassistant.util.yaml.loader] unacceptable character #x0000: special characters are not allowed
2020-11-06 16:11:44 ERROR (MainThread) [aiohttp.server] Error handling request
self.update(1)
resp = await task
The (corrupted) automations.yaml can be found here: https://gofile.io/d/ocCoZx
So the automation it crashed on was for lighting based on a movement sensor, basically involving ‘device’ triggers, ‘sun’ and ‘time’ conditions and device light turn on actions. Everything selected in the UI.
I’ve also edited the automations name before saving, that might have something to do with it.
