I have created the following automation:
# Wohnzimmer-Lampensteckdose ***********************
- alias: Lampe ein-aus-ein-aus
- platform: time
at: '05:30:00'
- platform: time
at: '23:59:00'
- platform: state
entity_id: binary_sensor.hell
to: 'on'
- platform: state
entity_id: binary_sensor.dunkel
to: 'on'
service_template: >
{% if trigger.platform == 'time' %}
switch.turn_{{ 'on' if now().hour == 5}}
switch.turn_{{ 'off' if now().hour == 23 }}
{% endif %}
{% if trigger.platform == 'state' %}
switch.turn_{{ 'off' if trigger.entity_id == 'binary_sensor.hell'}}
switch.turn_{{ 'on' if trigger.entity_id == 'binary_sensor.dunkel'}}
{% end
entity_id: switch.38272685dc4f22ead1ee
but it does not do what it should. Where did I make a mistake? can someone help me?
The automation should switch ON the lamp at first at 5:30 and switch OFF at the latest 23:59.
If the brightness sensor detects ‘dark’, the lamp should also be switched on. If the brightness sensor detects ‘bright’, the lamp should be switched off.
The result should be that the lamp is on from 5:30 in the morning until sufficient daylight is available and turns ON when it gets dark again and then turns off again at 23:59.
Many thanks for the help
