MR-KGB
March 30, 2020, 3:54pm
1
I’m using the Plugin : (Xiaomi) Vacuum Card. from HACS to see the status of the automower
entity: vacuum.(your automower name)
image: >-
https://s2.qwant.com/thumbr/700x0/c/6/1a04d98ebdf37c8e35ec4f12276d604e3e936a88ee3d9aea52759ca5c75b01/Husqvarna-Automower-315-Robotic-Lawn-Mower-01.jpg?u=http%3A%2F%2Fcdn.thegadgetflow.com%2Fwp-content%2Fuploads%2F2017%2F04%2FHusqvarna-Automower-315-Robotic-Lawn-Mower-01.jpg&q=0&b=1&p=0&a=1
type: 'custom:xiaomi-vacuum-card'
buttons:
locate: false
The result is shone
A huge shoutout to nikrolls for the ha-automower
And to benct for the lovelace-xiaomi-vacuum-card
nickrout
(Nick Rout)
March 31, 2020, 10:44pm
2
This makes me wish I had a lawn instead of a hillside.
MR-KGB
April 1, 2020, 2:57pm
3
I do know that they have the 435 AWD a 4*4 automower that can mow 35° incline but it is crazy expansive
Just used your setup and… it´s looking good! Will try it over the next few days. THanks for pointing it out!
MRobi
(Mike)
June 14, 2020, 2:32pm
5
Glad I stumbled on this post, the card looks much better than the regular entity card. I saved the image to the local directory so it doesn’t rely on the web to pull it in.
MR-KGB
June 21, 2020, 6:34pm
6
I did this in the example so you can just copy and paste the code and it will work but thank to point this out
gidadavid
(Gidadavid)
January 27, 2021, 12:01pm
7
Is there a way to change the names of the sensors ? I don’t need a Main Brush on my smart mower
Greets
entity: vacuum.automower
image: >-
buttons:
locate: false
I have a 430x but mine seems to only display the battery and current mode!
Do you know if there is way to only display used service (battery and current state)
Add state and attributes and you’ll end up with what you need.
image: >-
style: 'ha-card { height: 310px; }'
state:
mode: false
attributes:
main_brush: false
side_brush: false
filter: false
sensor: false
I want to get rid of the return to base button, does anyone know what its called? Thanks
vormsty
(Vormsty)
June 7, 2021, 7:16pm
12
I juat want to send an order to go home for the automover.
Can your tell me how to do that ?
I would like to send this order when it is rainy…
Best regards
Thierry
MR-KGB
August 2, 2021, 9:41am
13
vormsty:
Thierry
You can use an automation this would work fine.
alias: Send Automower home when it's raining outside
description: ''
- platform: state
entity_id: weather.home
to: rainy
condition: []
- service: vacuum.return_to_base
entity_id: vacuum.automower
mode: single
Tell me if this work for you.
Best regards
