I have at home an autoshutoff valve that is connected to an Insteon controller.
I’ve decided for multiple reason to remove insteon devices slowly from my home. The valve itself is dumb, so I figured it will work with any relay. So I bought a zigbee relay. I tried to wire it up but it doesn’t seem to work. Included a wire up of the existing valve with the insteon controller. And I included also the zigbee relay I got. Any help is much appreciated. I might not have the wiring done properly.
What voltage does the valve operate off of?
it’s a 12V.
