Autoslide - key switch cable or rs485
hi all,
can anyone recommend which device would be best to integrate and use this feature: https://autoslide.gorgias.help/en-US/integrating-my-system-with-3rd-party-devices-336516 with the autoslide product?
Would a shelly 1 work? i am trying to get more info from autoslide but just getting links to articles so far. hopefully they can help a bit more.
thank you very much
seems it would be something like this Industrial RS232 RS485 Serial to WiFi & Ethernet Converter with Modbus
But I am not sure how to then hook it up to home assisant. do i need to use a specific type of module - perhaps esphome?
or i can use https://attachments.gorgias.help/uploads.gorgias.io/0l9dY2VKggd7rZkL/AutoSlide_-_Key_Switch_Cable_Guide-fb43c96a-cc89-41d9-ae5b-913fbdd7fda2.pdf
maybe a smaller rm4 could be hooked up to this?
Seems like I should try something like this and just wire up Shelly Pro 3, Smart Home Automation Australia
So I found a lot more about this in case it helps others and will update this thread
The cable that you get can only tell the door to open. I’m not sure how long you can keep it open without changing the mode, but you cannot change the mode through third party. You can only change the mode of the system with the key fob, wireless or on the device itself
We often leave our sliding door open during the day and summer to let the cool air in, so this is definitely something I need to solve.
