Autostart dashing not working
After some attempts I managed to get hadashboard running on my Pi3. Main challenge I am facing now is to have it autorun. I edited the init file dashing as below. I copy it to /etc/init.d and chmod it correctly. Now when I manually run dashing te word “dashing” will be written on my screen over and over and ultimately locks up my pi. What am i doing wrong?
NAME=dashing
DASHING_DIR=/home/pi/hadashboard
DAEMON=/etc/init.d/dashing
PIDFILE="$DASHING_DIR/$NAME.pid"
DAEMON_OPTS=“start -d -P $PIDFILE”
GEM_HOME=/home/pi/.rvm/rubies/ruby-2.3.3/bin/gem
What version of ruby did you install and is the path correct?
Mine looks like this.
NAME=dashing
DAEMON=/usr/local/bin/dashing
DAEMON_OPTS="start -d -P $PIDFILE"
GEM_HOME=/usr/local/lib/site_ruby/gems/1.9.1
I had dashing automatically started on my RPi3 today, and I have the same value as BarryHampants for DAEMON :
# Must be a valid filename
NAME=dashing
GEM_HOME=/var/lib/gems/2.1.0
I installed it manually, not with docker
For the GEM_HOME path, I used the command
gem environment
And used the first line given in the GEM PATH section :
RubyGems Environment:
  - RUBYGEMS VERSION: 2.2.2
  - RUBY VERSION: 2.1.5 (2014-11-13 patchlevel 273) [arm-linux-gnueabihf]
  - INSTALLATION DIRECTORY: /var/lib/gems/2.1.0
  - RUBY EXECUTABLE: /usr/bin/ruby2.1
  - EXECUTABLE DIRECTORY: /usr/local/bin
  - SPEC CACHE DIRECTORY: /home/pi/.gem/specs
  - RUBYGEMS PLATFORMS:
    - ruby
    - arm-linux
  - GEM PATHS:
     - /var/lib/gems/2.1.0
     - /home/pi/.gem/ruby/2.1.0
     - /usr/share/rubygems-integration/2.1.0
     - /usr/share/rubygems-integration/all
  - GEM CONFIGURATION:
     - :update_sources => true
     - :verbose => true
     - :backtrace => false
     - :bulk_threshold => 1000
  - REMOTE SOURCES:
     - https://rubygems.org/
  - SHELL PATH:
     - /usr/local/sbin
     - /usr/local/bin
     - /usr/sbin
     - /usr/bin
     - /sbin
     - /bin
     - /usr/local/games
     - /usr/games
Tried all your suggestions, but even after the tip of @nicop4 it still doesn’t work.
pi@pi:~ $ gem environment
  - RUBYGEMS VERSION: 2.6.8
  - RUBY VERSION: 2.3.3 (2016-11-21 patchlevel 222) [armv6l-linux-eabihf]
  - INSTALLATION DIRECTORY: /home/pi/.rvm/gems/ruby-2.3.3
  - USER INSTALLATION DIRECTORY: /home/pi/.gem/ruby/2.3.0
  - RUBY EXECUTABLE: /home/pi/.rvm/rubies/ruby-2.3.3/bin/ruby
  - EXECUTABLE DIRECTORY: /home/pi/.rvm/gems/ruby-2.3.3/bin
  - SYSTEM CONFIGURATION DIRECTORY: /home/pi/.rvm/rubies/ruby-2.3.3/etc
    - ruby
    - armv6l-linux
  - GEM PATHS:
     - /home/pi/.rvm/gems/ruby-2.3.3
     - /home/pi/.rvm/gems/ruby-2.3.3@global
     - :verbose => true
  - REMOTE SOURCES:
  - SHELL PATH:
     - /home/pi/.rvm/gems/ruby-2.3.3/bin
     - /home/pi/.rvm/gems/ruby-2.3.3@global/bin
     - /home/pi/.rvm/rubies/ruby-2.3.3/bin
     - /usr/local/sbin
     - /usr/local/bin
     - /usr/sbin
     - /usr/bin
     - /sbin
     - /bin
     - /usr/local/games
     - /usr/games
     - /home/pi/.rvm/bin
     - /home/pi/.rvm/bin
     - /home/pi/.rvm/bin
Based on that I changed dashing to:
NAME=dashing
GEM_HOME=/home/pi/.rvm/gems/ruby-2.3.3
But if I know run dashing (in /etc/init.d) I get “Could not locate Gemfile or .bundle/ directory”…
If I simply go to /home/pi/hadashboard and execute “dashing start” from there everything works perfectly.
You have to be in the correct directory when you run dashing start or it will break. That is what the dashing_start.sh script does in the distro - run that instead of “dashing start” in your startup script (after editing it appropriately for your path to dashing) and it should work.
Same problem here from /home/pi/hadashboard/ run perfectly… but i cant make it to start… can somebody point how we can check this values? i.e GEM_HOME, DASHING DIR, PATH, etc ???
Ok, tried to document steps a bit, but it is still not working. See documented steps below.
NAME=dashing
#DASHING_DIR is where hadashboard is installed. Do note the trailing slash as it is a directory
DASHING_DIR=/home/pi/hadashboard/
#DAEMON can be found by typing "which dashing"
DAEMON=/home/pi/.rvm/gems/ruby-2.3.3/bin/dashing
#Don't change the PIDFILE
#Don't change the DAEMON_OPTS
#GEM_HOME is the first line under "Gem Paths" when you type "gem environment"
I decided to change hadashboard_start.sh to below and to add that to the crontab @reboot.
#!/bin/bash
cd /home/pi/hadashboard
start-stop-daemon --start --quiet --chdir /home/pi/hadashboard/ --exec /home/pi/.rvm/gems/ruby-2.3.3/bin/dashing -- start -d -P /home/pi/hadashboard/dashing.pid
EDIT: this also doesn’t work… :disappointed:
tonight im gonna start with a fresh instalation, and I´ll try docker for RPI, if it works i´ll post the steps.
@aimc I know you´re the Jedi here, any recomendations?
Thanks!!!
The whole start up thing is hard to help with because it is different for every platform …
All I can say is, use the force …
