Autostart esphome dashboard
I’m rather new to Linux, so here’s my question :
each time I want to start esphome Dashboard I need to type in “esphome config/ dashboard”
What do I need to do so that the esphome dashboard starts automatically on my linux system?
I would use systemd
What Linux?
Debian
so lets see if I’m right :
  • first create a file in /etc/system/system : “esphomeDashboard.service”
  • add following to the file :
    [Unit]
    Description= ESPHome Dashboard
    After=network-online.target
    [Service]
    Type=simple
    User=%i
    ExecStart=/usr/local/bin/esphome config/ dashboard
    Restart=on-failure
    RestartSec=5s
    [Install]
    WantedBy=multi-user.target
  • then a : sudo systemctl --system daemon-reload
  • after that enable the service : sudo systemctl enable espHomeDashboard
  • And then after a reboot it should work, right?
3 questions :
  • Is this the right way to autostart something?
  • what do I fill in after the “After=”? Is “network-Online.target” ok?
  • What do I fill in at the “ExecStart=” line?
thanks for any help…
edit : ok, the above seems to work after a reboot I can access the dashboard, but now it seems that although the configured Sonoff switch (with espHome) is still working inside my Home Assistant, it doesn’t appear on my ESPHome Dashboard.
ESPHome Dashboard even says that the are no nodes configured yet, like the first time you setup ESPHome
What could be wrong here?
You might need to set the working directory for the service:
WorkingDirectory=/home/wherever_your_config_is
Should be in the line after [service]
Or add the full path to the config directory in the line above.
Hello guys! :slight_smile:
I was not able to use ESPHome as a systemd because of the following error:
FileNotFoundError: [Errno 2] No such file or directory: ‘esphome’: ‘esphome’
Until I added Environment=PATH under [Service] section:
[Service]
Environment=PATH=/srv/homeassistant/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
Notice the /srv/homeassistant/bin in PATH - that’s my virtualenv directory for ESPHome anf Home Assistant…
My working configuration on Debian:
/etc/systemd/system/esphomeDashboard.service
[Unit]
[Service]
Type=simple
User=root
ExecStart=/usr/local/bin/esphome /root/config/ dashboard
Restart=on-failure
RestartSec=5s
[Install]
After file is created , run
systemctl daemon-reload && systemctl start esphomeDashboard.service
hello,
I cannot find why my esphome cannot autostart / start when i make ’ systemctl start esphomeDashboard.service’ i get error like this:
Failed to start esphomeDashboard.service: Unit esphomeDashboard.service has a bad unit file setting.
Here my /etc/systemd/system/esphomeDashboard.service file:
[Unit]
[Service]
Type=simple
User=%i
Restart=on-failure
RestartSec=5s
[Install]
Anybody can help me please?
what is
config/
supposed to do?
directory for esphome nodes configuration.
No it is not. see esphome --help
root@nuccy:/config# esphome --help
usage: esphome [-h] [-v] [-q]
               [configuration [configuration ...]]
               {config,compile,upload,logs,run,clean-mqtt,wizard,mqtt-fingerprint,version,clean,dashboard,vscode,update-all}
ESPHome v1.14.3
positional arguments:
  configuration         Your YAML configuration file.
                        Commands
    config              Validate the configuration and spit it out.
    compile             Read the configuration and compile a program.
    upload              Validate the configuration and upload the latest
                        binary.
    logs                Validate the configuration and show all MQTT logs.
    run                 Validate the configuration, create a binary, upload
                        it, and start MQTT logs.
    clean-mqtt          Helper to clear an MQTT topic from retain messages.
    wizard              A helpful setup wizard that will guide you through
                        setting up esphome.
    mqtt-fingerprint    Get the SSL fingerprint from a MQTT broker.
    version             Print the esphome version and exit.
    clean               Delete all temporary build files.
    dashboard           Create a simple web server for a dashboard.
    vscode              ==SUPPRESS==
    update-all          ==SUPPRESS==
optional arguments:
  -h, --help            show this help message and exit
  -v, --verbose         Enable verbose esphome logs.
  -q, --quiet           Disable all esphome logs.
Now I am confused though. My docker install is running
root@nuccy:/config# ps ax
  PID TTY      STAT   TIME COMMAND
    1 pts/0    Ssl+  72:51 /usr/bin/python3 /usr/local/bin/esphome /config dashboard
   37 pts/0    S+     0:00 /usr/bin/python3 /usr/local/bin/esphome --dashboard -q /config vscode --ace
Yet config/ or /config is undocumented.
Setup systemd unit file with virtualenv and pip.
You will need python-virtualenv and python-pip packets installed.
  1. Create esphome user.
sudo useradd --home-dir=/opt/esphome --create-home esphome
  1. Create virtualenv and install esphome from pip
sudo su - esphome
virtualenv --python=python3 ENV
source ENV/bin/activate
pip install esphome
  1. Exit from esphome user (print exit or hit CTRL+D) and create systemd unit file /etc/systemd/system/esphome.service
[Unit]
Description=esphome
After=network.target
[Service]
Type=simple
User=esphome
WorkingDirectory=/opt/esphome
ExecStart=/opt/esphome/ENV/bin/python /opt/esphome/ENV/bin/esphome config/ dashboard
RestartSec=30
Restart=on-failure
Environment="PATH=/opt/esphome/ENV/bin"
[Install]
  1. Reload systemctl, start, check and enable esphome.service
systemctl start esphome.service
systemctl status esphome.service
systemctl enable esphome.service
Thanks for sharing this.
I thought I would share the addition I had to make in order to make it work.
Not sure if it is because of my linux distrib or the new version of platformio, but I had to add a bit more in the PATH variable:
Environment="PATH=/opt/esphome/ENV/bin:/usr/local/sbin:/usr/local/bin:/usr/bin"
Otherwise it would not compile properly on the beta version at least (esphome v1.15.0b4)
For anyone on a rPi my working service is:
[Unit]
[Service]
WorkingDirectory=/home/pi/config
User=pi
ExecStart=/home/pi/.local/bin/esphome config dashboard
Restart=on-failure
RestartSec=5s
[Install]
Then:
sudo systemctl daemon-reload && sudo systemctl start esphomeDashboard.service
this works for me and compiling is working.
and no erros in the log of the service:
sudo systemctl status esphomeDashboard.service
[Unit]
[Service]
User=pi
Restart=on-failure
RestartSec=5s
Environment="PATH=/home/pi/.local/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games"
[Install]
Really useful, thanks. I have made a couple of adjustments - this is on a Raspberry OS 64 bit system. Main thing is that you should not put the service file in /etc/systemd/system/ as if you use systemctl delete it will remove the service file completely.
NOTE Edited original post
Commands from clean install of PiOS
sudo apt-get update
sudo apt-get -y upgrade
sudo apt install python3-pip python3-venv
sudo su - esphome
python3 -m venv venv
source venv/bin/activate
pip install esphome
Create a small script to start the dashboard
nano start.sh
with
#!/bin/bash
esphome dashboard /opt/esphome/config/
set as executable
chmod +x start.sh
Then exit the esphome user and create the service file.
sudo nano /lib/systemd/system/esphomedashboard.service
with is file contents
[Unit]
Description=ESPHome Dashboard Service
[Service]
Type=simple
User=esphome
ExecStart=/opt/esphome/start.sh
RestartSec=30
Restart=on-failure
[Install]
Then to activate
sudo systemctl start esphomedashboard.service
systemctl status esphomedashboard.service
If you want it to start at boot;
sudo systemctl enable esphomedashboard.service
If you are looking for the config files, they will be found in /opt/esphome/config/
The above works on 64bit PiOS, if you want to do it on 32bit PiOS you need to install libssl-dev and rust;
sudo apt-get update
sudo apt install -y python3-pip python3-venv libssl-dev
sudo su - esphome
curl https://sh.rustup.rs -sSf | sh
source $HOME/.cargo/env
rustc --version
pip install esphome
Does anyone know how to update esphome when setup like this (I’m not used to VENVs)?
I’d like to use a script or just a cron job to update it.
anyone using systemd in Kali linux running in WSL?
I had to rework just a bit to make it work on ubuntu 22.04 in a mini-pc.
[Unit]
[Service]
Type=simple
User=esphome
#ExecStart=/usr/local/bin/esphome /administrator/config/ dashboard
ExecStart=/opt/esphome/.local/bin/esphome dashboard /opt/esphome/config/
Restart=on-failure
RestartSec=30
Environment="PATH=/opt/esphome/.local/bin"
[Install]
