Autostart of SSH Tunel on RPi Docker
RPi Docker
i have made HA work behind Nat with SSH Tunel.
The only problem is autostart of if.
If i start a command from RPi’s CLI
ssh -p 22 -o ExitOnForwardFailure=yes -o ServerAliveInterval=60 -N -R 31281:localhost:8123 [email protected]
Tunnel works perfect.
I created a file /etc/systemd/system/ha-tunnel.service
[Unit]
Description=Tunnel for HA
After=network.target
[Service]
ExecStart=/usr/bin/ssh -p 22 -o ExitOnForwardFailure=yes -o ServerAliveInterval=60 -N -R 31281:localhost:8123 [email protected]
RestartSec=5
Restart=always
[Install]
WantedBy=multi-user.target
And then try to start it with
sudo systemctl start ha-tunnel
and it do not starts.
Staus shows me
 Loaded: loaded (/etc/systemd/system/ha-tunnel.service; enabled; vendor preset: enabled)
   Active: activating (auto-restart) (Result: exit-code) since Wed 2020-08-12 01:08:24 BST; 3s ago
  Process: 10634 ExecStart=/usr/bin/ssh -p 22 -o ExitOnForwardFailure=yes -o ServerAliveInterval=60
 Main PID: 10634 (code=exited, status=255/EXCEPTION)
What have i’ve done wrong?
Thanks a lot!
I have solved it.
Just need to add some lines.
Here is the final version that works perfect!
[Unit]
ConditionPathExists=|/usr/bin
[Service]
User=pi
ExecStart=/usr/bin/ssh -i "/home/pi/.ssh/id_rsa" -p 22 -o ExitOnForwardFailure=yes -o ServerAliveInterval=60 -N -R 31281:localhost:8123 [email protected]
RestartSec=5s
Restart=always
[Install]
Why not use autossh instead.
If i could know about it…
